Phenolic intake spacer for 99-04 split port Mustang - Mustang Evolution
Old 04-12-2016, 12:46 PM   #1
CajunStang02's Avatar
I have an '02 3.8 that I have had for some years now and am able to actually play around with it and do some performance mods. I recently purchased the windstar intake from a local parts yard for the infamous intake swap. I know there are clearance issues with the swap as for the fuel rails, egr, hood, etc. I got another hood as well to modify for the clearance issue. I read elsewhere that a Phenolic Intake Spacer could help with the clearance of the fuel rails while adding a few more hp/trq. Looked around for one with no luck. If anyone here has a lead on one it would be greatly appreciated. Just trying to boost my stang a little bit to be more fun as a DD car. Any help is appreciated.
CajunStang02 is offline   Reply With Quote
Old 04-18-2016, 09:59 AM   #2
kickerofdoom's Avatar
Vap auto was the one I got mine from it helps I felt more power not much but something
Old 04-20-2016, 12:41 PM   #3
Yea, VAP auto is no more as far as I can tell. I know I'm late to the windstar swap craze. Was just trying to find if anyone knew of someone that may have done the swap and then changed something up and no longer needed some parts. I was also looking for the angled TB spacer that VAP sold. I have a local machine shop that may be able to make the TB spacer and possibly the intake spacer.
Old 05-29-2016, 07:28 AM   #4
The intake spacer is nice and easy to install but the windstar intake has many more benefits and will make more power. You can always just change the hood or cut in it. Good luck
Old 06-01-2016, 10:58 AM   #5
I have all the parts I need for the swap. Just have to find time to tackle everything. Once I get the intake on I'll be able to finish the hood modification. Got a hood from the junk yard, going to fiberglass a cowl and make a heat extractor hood. Any tips on installing the intake that could save me some time and headaches?
single port or split port 97 stang Pre-2005 V6 Mustang 8 10-10-2008 06:51 PM
single port to split port conversion NorwegianMustang Pre-2005 V6 Mustang 3 06-19-2006 03:19 PM
My terminology for single port and split port RGR Pre-2005 V6 Mustang 0 01-03-2004 10:03 AM
02:27 PM
