'01 bogs down and backfires - Mustang Evolution
Old 04-13-2016, 09:05 AM   #1
Dasan458's Avatar
So I just solved the CCRM problem and now I have a new one. When I press on the gas more than normal, it bogs down and backfires. This has gotten worse to the extent that it started misfiring and just a simple tap on the gas caused the episode. Now im stuck on the side of the road cause it died and it won't start. It wants to start but won't.
Sent from my XT1254 using Mustang Evolution mobile app
Chevy runs deep, Ford pulls them out
Dasan458 is offline   Reply With Quote
Old 04-13-2016, 09:07 AM   #2
Dasan458's Avatar
Also I have replaced the fuel pump and fuel filter
Old 04-13-2016, 10:23 AM   #3
Dasan458's Avatar
I was able to get it running and drive it home. Forgot to mention that in neutral or park it's fine but when Im driving it seems to do it when it's in a higher gear and trying to downshift. Also the misfiring is random. At times it won and at times it will misfire almost constantly. I tried unplugging the MAF sensor and it started missing really bad a almost died. I plugged it back in but it didn't change anything
Old 04-13-2016, 04:31 PM   #4
Dasan458's Avatar
Ran the scanner. Got code p0113. Intake Air Temperature High Input
Old 04-13-2016, 05:30 PM   #5
Dasan458's Avatar
So I cleaned the MAF and the IAT sensor and erased the codes. It at least starts up faster but it still bogs down. Not as much. Ran the scanner again several times and the code has not shown up again. Im banking on the catalytic converter being clogged? cause it backfires on the right engine bank
Old 04-14-2016, 07:18 PM   #6
Dasan458's Avatar
I feel like I'm talking to myself. I did a fuel pressure test and it was running 12-15 psi and when the engine revs, it drops. Also when the engine shuts off it drops to 0 psi.
Engine bogs down over 2500 RPM aforceman 1979-1995 Mustang GT 11 07-02-2015 10:32 AM
Backfires when cold tonyjuan 2005-2010 Mustang GT 7 02-19-2013 03:12 PM
95 v6 mustang bogs down when it gets warmed up stevens005 Pre-2005 V6 Mustang 5 03-10-2009 08:08 PM
Plan backfires: Porn for every child wiarumas The Bar 7 07-20-2007 08:49 PM
07:33 PM
