comp cam question - Mustang Evolution
Old 04-27-2016, 12:56 AM   #1
comp cam question
not really sure how to explain this but, I just installed strip and street comp cam in my 2000 v6 but think they may have sent me the wrong cam because when I turn the crank by hand the cam wont spin because the comp cam is not set up like my stock cam. stock cam has a tooth that can lock into the cam gears that makes it spin with the crank but my new cam has a dip in it where the tooth should be which wont allow it to properly aligned with the gears. first pic is my comp cam 2nd is my stock. Is this how they sell these. expected to have this done by tomorrow.
ID:	200324   Click image for larger version
tyronekndrck is offline   Reply With Quote
Old 04-27-2016, 01:52 AM   #2
You need to remove the keyway from the slot in your old camshaft and insert it into the slot in your new camshaft.
It can be removed by pounding a small screwdriver or chisel underneath the keyway until it lifts out of the slot. Or you can purchase a new one to install. I'm not sure if the auto parts stores have them, but the camshaft keyway is probably available at your local Ford dealership.
straybullitt is online now   Reply With Quote
Comp Cam Swap/ Tools Maypo 2005-2010 Mustang GT 6 02-15-2016 12:59 AM
Stage 1 Comp Cams and adjustable Cam Gears. Beampit 1996-2004 Mustang GT 6 04-07-2013 12:34 AM
Comp Cam dealer in Sao Paulo KaraKedi Classic Mustangs 1 11-22-2011 11:42 AM
3.8 V6 Comp Cam Performance Cam nmaraijko Mustang Parts for Sale and Wanted 0 11-15-2006 07:11 AM
Cam Cores needed for RDMotorsport cam GP RGR Mustang Parts for Sale and Wanted 3 03-05-2005 05:53 AM
05:27 PM
