Clogged cat causing an exhaust leak - Mustang Evolution
Old 05-08-2016, 05:28 PM   #1
Iryan7's Avatar
So here's the situation, I had a passenger side exhaust leak (manifold broke at the flange) for a while. After fixing it everything was great for a month, then I developed a driver's side leak which is now as bad as the passenger side leak was. Could a clogged cat be causing excessive back pressure making it the source of the problem? What is a good way to tell if my cat is clogged? Thanks in advance
2001 3.8 201,xxx mi
Sent from my SM-G920T using Mustang Evolution mobile app
Iryan7 is offline   Reply With Quote
Old 05-11-2016, 11:21 PM   #2
Revvv's Avatar
The engine in my Ram is blown due to a clogged cat. It never really gave me a warning that I associated with a catalytic converter.
Check for a sulfer smell, a loss in power, and other issues.
Also pull the dipstick and smell the oil. You will know if the cat is clogged.
exhaust
Clogged/broken cat behemoth 1996-2004 Mustang GT 0 12-26-2014 09:35 PM
Clogged cats. Grimace96 1996-2004 Mustang GT 37 05-29-2014 05:29 AM
Clogged Cats buickregal79 1996-2004 Mustang GT 11 09-03-2013 12:47 PM
95gt excessive oil leaks, clogged pcv screen. james90LX 1979-1995 Mustang GT 1 11-13-2012 10:01 PM
2000 v6 possible clogged radiator? HELP! 200v6 New Member Introductions & Greetings 7 01-27-2011 04:26 AM
03:39 AM
