Transmission Check Valve - Mustang Evolution
Old 05-13-2016, 12:34 PM   #1
Ok guys I have a 2014 Mustang V6 Automatic, and this is something I keep seeing floating around. I am told you CANNOT flush this transmission because it has a check valve that keeps the fluid from circulating properly. However I am also hearing that when you bring it to Ford for servicing they flush it. I have also heard Ford just does a pan drop and does not flush it. The whole reason for this post is I am looking to buy a transmission flush machine and I have come across a few deals but don't know if I should or should not buy it. I mean if I can't use it on my 'stang why bother.
Logan541 is offline   Reply With Quote
Old 05-22-2016, 06:12 PM   #2
FastFord13's Avatar
Wrong section.
Sent from the future.
FastFord13 is online now   Reply With Quote
Does a 98 have a single over___ valve or double ____ valve? SwatKatz901 1996-2004 Mustang GT 14 02-13-2012 07:03 AM
16 Valve GT To 32 Valve Cobra Engine Swap 504 Stang Rida 1996-2004 Mustang GT 5 08-23-2011 05:29 AM
where pcv valve on my 3.8L v6 valve cover to where? Pascullon Pre-2005 V6 Mustang 2 02-28-2011 08:47 AM
Is a valve gasket the same as a valve cover gasket? birtingr General Mustang Discussion 6 03-15-2010 02:24 AM
Bypass valve & Blowoff valve sporter 2005-2010 Mustang GT 7 05-27-2007 02:57 PM
05:22 PM
