Auto to Manual Swap (theft) help - Mustang Evolution
Old 06-02-2016, 09:08 PM   #1
Dasan458's Avatar
So I need some help on this. I have (allmost) everything I need for the swap. I went to LQK and got the parts off of a 2003 (mine is '01) mustang. T-45 trans, wire harness, computer, pedal assembly, clutch cable, flywheel, shifter, and driveshaft. Btw, I haven't yet swapped yet, but I need to get one piece of info before I do so.
So I have researched a bit and can't get a definitive answer. If I use the computer will it trip the PATS? I cannot go and get the PATS off the donor car cuz it's crushed. I'm also stuck between a rock and a hard place with this because I also have a '99 with 5spd but the ignition is shot so I can't use the PATS and key from that either. What are your suggestions. I don't want to go to the dealership and have them flash the computer cuz i don't have the money.
Chevy runs deep, Ford pulls them out
Dasan458 is offline   Reply With Quote
Old 06-02-2016, 10:37 PM   #2
Revvv's Avatar
I am going to watch this thread to see what answers are given.
I hate the PATS, VATS, and other security systems used. No one is thinking about vehicles used 10 years later.
I can't wait to get a program for my 02 Mustang that disables the PATS. Once that happens I am putting in a true push button ignition with the ACC position switch hidden.
Old 06-03-2016, 10:02 AM   #3
Dasan458's Avatar
Yea I would like to disable PATS altogether. It's a POS
Sent from my XT1254 using Mustang Evolution mobile app
Old 06-03-2016, 11:40 AM   #4
Dasan458's Avatar
So a friend suggested this:
"Go ahead and use the PATS box and computer from the 99 parts car and tape the key to the box, that should keep the PATS from tripping."
Can anyone confirm this?
Old 06-03-2016, 02:02 PM   #5
Revvv's Avatar
If you are using the computer from the 99 it may work.
Old 06-03-2016, 06:46 PM   #6
Dasan458's Avatar
So where is this PATS module? It's not the thing in the trunk on the left, that the fuel pump driver module. And I took the black box out that is located beside the fuse box under the dash and ran the numbers, that came back as the alarm, not the anti theft. Any ideas where is would be?
Old 06-03-2016, 06:49 PM   #7
Dasan458's Avatar
And also a "quick Google search" brings up more posts of people that also have no clue where it's located. I found a diagram and I looked where the diagram says to look, but it was not there.
Old 06-03-2016, 07:57 PM   #8
Revvv's Avatar
The PATS system is on the column, right around the ignition switch.
Old 06-03-2016, 09:16 PM   #9
Get a tuner and disable it. Or just have your auto functions turned off in your PCM with said tuner and forget about PATs.
Also 2003s had T3650s, not T45s.
Old 06-03-2016, 09:20 PM   #10
Revvv's Avatar
How can you turn off PATS without a written program. I have an SCT and have not seen an option.
Old 06-03-2016, 09:22 PM   #11
You get a tune burnt that has PATs disabled... or he uses the auto computer he already has and just has the tune writer turn off all the auto features. You do not need a new PCM going from auto to manual but you do the other way around. Or he could just stay auto and throw a converter in there with a set of 4.10s and be faster than he will be with the stick.
Old 06-03-2016, 09:25 PM   #12
Revvv's Avatar
That makes sense. I was beginning to think I missed something somewhere in my programmer.
Old 06-05-2016, 11:31 PM   #13
Dasan458's Avatar
I will be keeping the auto computer and transmission for later, but for right now I'm putting the 5spd in for mpg. What I'm gonna do is put the 5sp in, drive down to Ford, put the manual computer in there, and have them turn off the PATS. I already talked to them and it's cheaper than a scanner. But later I will be getting a shift kit and converter and putting the auto back in, but that will be a few years ahead. And getting 4.10. thanks Scott for the inspiration.
Old 07-15-2016, 09:23 AM   #14
I just did the same thing on my 98 mustang an i found out the the computer that it has with an automatic works with the 5 spd an every thing works just fine
Sent from my SAMSUNG-SM-G935A using Mustang Evolution mobile app
fastNfurious is offline   Reply With Quote
Old 07-16-2016, 10:25 PM   #15
Dasan458's Avatar
So you think it will work? I have read that there is a hesitation when gassing it because the computer thinks it has to downshift. Is this true in your experience?
Old 07-19-2016, 12:21 PM   #16
Dasan458 I haven't noticed it doing any hest. When I shift the only thing I found out is that u don't have to push the clutch in while starting it
Old 07-21-2016, 01:26 PM   #17
@Dasan458 it will work out fine
Old 07-21-2016, 02:00 PM   #18
Dasan458's Avatar
Ok thanks for the replies. This helped me a lot
Old 07-24-2016, 04:52 PM   #19
@dasan458 how the build going I'm stuck in want to get the exhaust that comes out the side by the doors instead of the back but don't know wear to look
Old 07-24-2016, 08:38 PM   #20
Dasan458's Avatar
@fastNfurious look up the 2000 cobra r. They had side exit exhausts. I also want to do this but mine is a convertible and the side braces are in the way. You will need to fabricate and weld on some exhaust hangers and pick up some rubber hangers at the parts store
Old 07-24-2016, 08:41 PM   #21
Dasan458's Avatar
Also I suggest getting flat tips to maximize the clearance from the tip to the ground
Old 07-25-2016, 08:08 AM   #22
@dasan458 cool thanks for the info ima check it out now
Auto to Manual Swap- Looking for a manual transmission for 2013 v6 Bdeysher21 2011-2014 V6 Mustang 27 12-25-2014 04:19 PM
Manual vs "auto manual" elkoritaNAY 2011-2014 V6 Mustang 5 08-24-2014 08:22 PM
Any one play ps3 grand theft auto? fishgonewild The Bar 16 05-06-2014 12:53 AM
Grand theft auto v Redstang1 The Bar 4 10-07-2013 07:41 AM
grand theft auto 00STANG00 The Bar 30 01-27-2010 12:31 AM
10:29 AM
