shaking and loss of acceleration - Mustang Evolution
Old 06-30-2016, 03:49 PM   #1
On trips of 3-4 hours, my 2001 Mustang begins to feel like it is not getting fuel. The gas pedal is non-responsive and the car starts to shake very badly. There is plenty of fuel, oil and water. The "check Engine" light is always on because I have not replaced the catalytic converter. This has happened three times now on the road, but my mechanic cannot duplicate the problem to diagnosis it or fix it.
Any ideas?
almb1214 is offline   Reply With Quote
Old 06-30-2016, 04:07 PM   #2
I would begin by replacing the fuel filter if you haven't already done it.
And check for any new codes. There may have been another one that has been triggered, that is unrelated to the catalytic converter code.
Old 07-01-2016, 08:45 AM   #3
Thanks. I have had the fuel filter replaced after the gas tank was replaced but I believe it needs to be done again. My mechanic doesn't agree but I'm going to insist
Old 07-01-2016, 10:09 AM   #4
Strange Mud's Avatar
i'd be considering the cat.....if you've already done the filter why would it need to be re-done?
Old 07-01-2016, 11:51 AM   #5
I had a truck that would act this way, turned out the coil would begin to misfire when it got hot. Attach a timing light to one of your wires when it starts acting up to see if the pulse is erratic.
sleeper is offline   Reply With Quote
Old 07-02-2016, 05:05 PM   #6
jeno's Avatar
Well from what you wrote especially about the cat it may be clogged and when it's getting hot enough causing the shaking and such just my opinion
Sent from my SM-N910T using Mustang Evolution mobile app
jeno is offline   Reply With Quote
Old 07-02-2016, 06:28 PM   #7
Revvv's Avatar
I can tell you that a clogged cat can cause catastrophic results in an engine. I have a Dodge Ram Quad Cab sitting in my driveway waiting for me to locate an engine.
Old 09-23-2016, 07:47 PM   #8
I had that problem a few years back with my 2001. I thought it was cats as well but it was a faulty egr valve, sensor and gas cap. It was a hot mess basically. Hope this helps!
CJZona is offline   Reply With Quote
Loss of Power and TC on AND off lights on butterflygrl 2011-2014 V6 Mustang 8 07-17-2014 06:00 PM
Play and shaking at the drive train? GT330 2005-2010 Mustang GT 9 10-09-2013 11:55 AM
Shaking and wanting to die after rev Speed_Mister 1996-2004 Mustang GT 11 02-11-2013 11:58 AM
Strange noise and clutch pedal shaking? rachaellee Pre-2005 V6 Mustang 5 10-24-2012 01:37 AM
Engine shaking at idle and driving stangin Pre-2005 V6 Mustang 18 03-22-2012 02:46 PM
03:00 AM
