Main 12v outlet not working - Mustang Evolution
Old 07-14-2016, 05:24 PM   #1
Iryan7's Avatar
The 12v/cigarette lighter near my gear selector randomly stopped working while the one in my center console still works. Does this mean the fuse isn't blown and I need to replace my 12v? I've made sure it's plugged in before anyone asks. Thanks in advance
Iryan7 is offline   Reply With Quote
Old 07-14-2016, 05:40 PM   #2
Strange Mud's Avatar
if it's random I would look at the plug have you tried plugging in another item? Maybe the plug is a bit loose.
by random sometimes it works or did it completely die?
Old 07-14-2016, 08:13 PM   #3
Iryan7's Avatar
The 12v has always worked until one day when I was using it to run a 12v air compressor and it suddenly shut off. Nothing works in it anymore but my 12v in the center console still runs the air pump fine.
Old 07-15-2016, 10:37 AM   #4
separate fuse (very good guess)
Old 07-15-2016, 02:49 PM   #5
Maybe you did, but you should always start your car before using your air pump--it draws a lot of amps and if the voltage is low, the amperage goes up (simple physics), which causes high heat. You might have burned a wire.
kipschitz is offline   Reply With Quote
Old 07-16-2016, 05:19 AM   #6
Kip good point!
Old 07-16-2016, 02:36 PM   #7
Iryan7's Avatar
Thanks for the tip, I'll have to trace my wire and make sure it's not burned. As for a separate fuse, do the outlets not share the same fuse? If not this would probably be the source to my problem.
Old 07-16-2016, 04:06 PM   #8
on my 2012 I doubt they do as the dash shuts off with no key.
12V Relay Brake Bypass? ColeJohnson Mustang Audio & Video 8 01-26-2012 10:22 AM
96 Cobra 12v power source Brad.krieg SVT Mustang 12 11-02-2011 02:38 PM
A\C working then not working Bohogin Pre-2005 V6 Mustang 3 07-14-2011 02:44 PM
12v power always on in shaker 500 sync? Blue Spirit General Mustang Discussion 2 04-20-2011 12:30 AM
Hid 5000k 12v 55w vs 35w 12v 5000k? eljin General Mustang Discussion 1 08-24-2009 06:29 PM
12:07 AM
