HELLLP!!!! running extremly rough - Mustang Evolution
Old 07-24-2016, 10:41 AM   #1
so I jus got finished installing new heads on my 2000 3.8 v6 , but when I went to start it seemed to have a bit of trouble turning over then bomb ww2 out of the exhaust. as it idles the RPM bounce up and down. when they go down the engine almost turns off and when its on the high side it feels like its being reved .I don't know what I did wrong or what step I may have forgotton to take, so any help will be greatly apreiated
Forest is offline   Reply With Quote
Old 07-24-2016, 11:03 PM   #2
Did you check both decks and heads for tolerances and before install? Did you replace head bolts?Did you bleed fuel system and check pressure? Did check engine compression after the job was done?most important did you torque everything to spec?Need more info but sounds like you have a timing issue prob didnt put cam sync back in right. Or maybe you just put rhe plug wires back wrong hope u figure it out good luck.
l2plagears is offline   Reply With Quote
Old 08-14-2016, 09:45 AM   #3
Hey guys I figgured it out a while ago but have had time to up date , n yes I did all those things n checked both surfaces for flatness , it was indeed a timeing problem, and had to be put at tdc b4 you torque in the rockers down Ina cretin order but thank you for all the replys
4.6 running rough / misfire 96Roushgt 1996-2004 Mustang GT 17 01-10-2013 10:53 AM
Car is running rough Nick.ward Pre-2005 V6 Mustang 9 01-09-2013 06:53 AM
Running Rough. ColeJohnson 1996-2004 Mustang GT 25 09-12-2011 03:46 PM
1999 ford mustang, running rough when getting hot? Grady 1996-2004 Mustang GT 1 03-08-2010 11:50 AM
Rough Idle and Rough Start Cajun JungleBoy Pre-2005 V6 Mustang 3 04-23-2006 10:33 PM
11:56 PM
