Cutting stock coil springs - Mustang Evolution
Old 08-27-2016, 10:27 PM   #1
MattMacFarlane's Avatar
Hey everyone,
I recently picked up a set of stock springs out of a 01 GT for my 1999 V6. My current springs have 247,000kms on them and are badly worn. I want a 1.5in drop all around but I cannot afford popper lowering springs as of yet. My shocks and struts are in decent shape and look to be newer than the springs.
So my question is: if I take 1/2 to 1 coil out the front and 3/4 off the rear will I get the drop I want and how much will it mess with my suspension/steering? Have any of you done this mod in the past and what were the results? I know my ride will be stiffer but I do 95% city driving and rarely on the highway. Thanks for your help guys. Cheers. Click image for larger version
Name:	ImageUploadedByMustang Evolution1472354827.611181.jpg
Live Strong-Drive Hard
MattMacFarlane is offline   Reply With Quote
Old 08-28-2016, 12:22 AM   #2
Revvv's Avatar
The springs are not progressive. The change in comfort and ride will be due to a shorter and more compressed shock.
1 full coil should put you where you want to be. If I had a set of spare springs I would cut a set and not worry about it.
Old 08-28-2016, 09:05 AM   #3
The current springs in my car have been blocked with pieces of 2x4 in the rear by the previous owner. I didn't notice this until I did a rear brake rebuild a couple of weeks ago. Cars been parked since. I picked up a set of GT springs to replace them and I would like a drop as well. I figured that a trimmed sprig would do the trick and has worked for my in the past.
A full coil front and back seems like a lot of drop. I'll try a 1/2 coil and see where that gets me. Thanks for the input.
Old 08-28-2016, 09:26 AM   #4
Strange Mud's Avatar
of course do what you want, but suspension (like brakes) is not something to do only 1/2 donkey. What about alignment, if you don't do it you'll go through tires. A drop is a luxury item wait till you can afford to do it properly.
.02
2012 V6 with suspension, shifting, stopping and sound mods.
Old 08-28-2016, 09:35 AM   #5
The car is in need of an alignment anyway. I've had decent success doing this in the past on other cars. Over the winter it's getting all new suspension from AM. This is a temp fix for the 4x4 look I currently have. I. Sporting almost 3in of wheel gap all around and it looks horrible.
Old 08-28-2016, 11:38 AM   #6
Revvv's Avatar
.02
Very true
Cutting stock springs Dgerow12 Pre-2005 V6 Mustang 20 09-01-2012 03:32 PM
Cutting stock springs? formulaDstang 2011-2014 Mustang GT 18 01-14-2011 07:28 PM
cutting stock springs sonicpony03 Pre-2005 V6 Mustang 11 06-24-2009 08:21 AM
Wanted: Stock coil springs and stock mufflers for '96 GT inaba116 Mustang Parts for Sale and Wanted 6 02-15-2006 10:19 PM
Cutting springs or Buying Springs Exit_In_Red Pre-2005 V6 Mustang 38 01-06-2005 01:13 AM
08:59 AM
