Dash HVAC illumination - Mustang Evolution
Old 09-11-2016, 07:21 PM   #1
MattMacFarlane's Avatar
Ok guys,
It's been a while since I posted about my dash, trac control switch and HVAC lights being dead in my 99. I've done some testing and I can say for certain this the problem seems isolated to the #5 fuse circuit:
1) the cluster is not U/S pictures above
2) I have power at the fuse block
3) I have power at the headlight switch
4) I do not have power at the pigtail that plugs into the back of the cluster in the car.
5) the headlight switch is new
Has anyone had this issue before? Where is this circuit grounded? Is there a place I should start my search effectively? Thanks in advance. RMR5685. Click image for larger version
Name:	ImageUploadedByMustang Evolution1473639597.697417.jpg
Live Strong-Drive Hard
MattMacFarlane is offline   Reply With Quote
Old 09-12-2016, 12:22 AM   #2
Revvv's Avatar
Bumping the thread so it gets noticed. Sorry about your electrical gremlin. I personally would have to chase each side and search for worn insulation, broken wires, or a loose ground. Also make sure all of the wires are firmly in their plugs.
Old 09-12-2016, 07:19 AM   #3
After an of testing and striking out and bring very confused I went back to the fuse block under the dash and pulled every fuse that was associated with the interior illumination and discovered that fuse #37 was defective, I had already replaced it once because it was blown. It wasn't blown it just wasn't carrying any current. Replaced the fuse and now life is good.
Now I just need to figure out why my constant 12v source (Lt Green and purple wire) for the radio isn't working. Already did the fuse block under the dash I'll check the under good ones in the morning.
Old 09-12-2016, 11:34 AM   #4
Revvv's Avatar
Glad to hear about the forward progress on the electrical nightmare.
Old 09-12-2016, 12:46 PM   #5
Now I just need to have the mystery auto starter/security system removed and the associated wires repaired.
As for the stereo situation, in the 99 mustang w Mach 460 the light green and purple wire is hot all the time correct? I do not have power at this wire only at the switched 12v black and pink. I suspect the fuse under the hood is to blame. Thoughts??
For Sale: 11-14 Laser Engraved Wind Deflector w/ Blue Illumination - Running Pony Mean14 Mustang Parts for Sale and Wanted 3 12-07-2015 08:20 PM
Gauge illumination when headlights come on Untamed5.0 2011-2014 Mustang GT 0 02-14-2013 07:25 PM
No trunk illumination? the_stig 2011-2014 V6 Mustang 6 06-25-2012 02:12 PM
1986 mustang guage cluster illumination ? columbanus 1979-1995 Mustang GT 1 12-15-2011 10:19 PM
Mustang Guage Cluster illumination.........? Clifton 1979-1995 Mustang GT 2 12-13-2011 02:01 AM
09:36 AM
