2001 cyl 3 and 4 misfire. - Mustang Evolution
Old 09-21-2016, 08:18 PM   #1
Dasan458's Avatar
I haven't had trouble with the stang in a while. I drove to College this morning and everything seemed fine. I parked it for 50 min then drove to another parking spot and turned it off for another 10 min. I came back to the car and started it and it ran slightly rough. I checked the codes and cyl 3 was misfiring first, only intermittently. Then cyl 4 started misfiring after a few min intermittently then both 3 and 4 were completely missing. I know a lot of people heard that even after changing coil pack, wires and plugs that it still misfires. I want to hear some opinions before I drop several hundred on those things and it not fix the problem. I replaced the plugs about 10k miles ago.
Sent from my XT1254 using Mustang Evolution mobile app
Chevy runs deep, Ford pulls them out
Dasan458 is offline   Reply With Quote
Old 09-22-2016, 08:09 PM   #2
Project Pony's Avatar
First check all your plugs and wires. Try switching the plugs that are missing onto cylinders that arn't missing. See if the miss follows. If it does then problem solved. If not there are a few other things to look at.
Sent from my SAMSUNG-SM-G920AZ using Mustang Evolution mobile app
[SIGPIC][/SIGPIC]
Old 09-22-2016, 08:11 PM   #3
How many miles are on the car? Could be a bad pack, but I'd start with the plugs and wires, then move onto checking voltages on the coil pack.
[SIGPIC][/SIGPIC]
Old 09-22-2016, 08:41 PM   #4
Dasan458's Avatar
It has 202,XXX miles. I did what you said switched plug wires and plugs. Misfire didn't change cyl. Got new coil pack and it cleared Up, post 3 & 4 were bad. Also installed new plugs and wires. I drove it home and it started and on cyl 2. Turns out that was a bad injector. Luckily I have a spare mustang and put a new injector on and it works perfectly again. Thanks for the suggestion, helped me out a lot and saved a few hundred bucks from having a mechanic misdiagnose it.😁 Hope this post helps someone else out in the future.
Old 09-23-2016, 07:28 PM   #5
Awsome, it's always nice to have a donor car to test stuff. Glad to hear you got it squared away.
[SIGPIC][/SIGPIC]
Old 09-24-2016, 12:03 AM   #6
Revvv's Avatar
The Pony has solved the mystery.
2004 V6 3.8L - Cyl. 1 misfire code badwolf2010 Pre-2005 V6 Mustang 5 12-28-2014 11:25 PM
Clutch replacement #4 cyl misfire gregtommy 2011-2014 Mustang GT 29 05-22-2012 09:52 AM
Grommet between Master brake cyl. and resevoir duals 1996-2004 Mustang GT 6 04-01-2009 07:16 PM
88 notchback.. 4 cyl.. MonteCitan Mustangs for Sale and Wanted 4 05-19-2006 02:13 PM
4 Cyl to a V-8 Firaboy 1979-1995 Mustang GT 9 07-16-2004 10:07 AM
05:07 PM
