clutch issue?????? - Mustang Evolution
Old 10-15-2016, 03:20 PM   #1
clutch issue??????
sometimes when I press in my clutch pedal I hear a whining or sqeeking sound when the car is running. Is that the clutch goin out! Hopefully not!
dsb567 is offline   Reply With Quote
Old 10-15-2016, 11:19 PM   #2
Revvv's Avatar
Throw out bearing, and / or pilot bearing. They are a constant problem with our cars.
Old 10-16-2016, 09:10 AM   #3
any idea
Any ideas on how to proceed? I'm not very experienced at car repairs.
Old 10-16-2016, 09:28 AM   #4
Revvv's Avatar
The transmission needs to be removed, and the throw out bearing will be riding on the shaft that connects the transmission to the engine. It is engaged via a clutch fork.
If you are not mechanically inclined, or have doubts about your abilities I would let someone else tackle the job. On our tightly packed cars things can be tough to reach. The job will take between 4 and 8 hours.
You have to remove the driveshaft, mid pipe, disconnect the clutch, remove the shifter inside the car, and then begin unbolting the trans bellhousing from the engine. Everything needs to be properly supported, and you may have a crossmember to remove.
I need to change my bearings and I have not done it yet.
A word of caution; if you wait too long you could end up with a frozen bearing that comes apart, or you could find the input shaft on the trans worn due to the bearing welding itself together.
Old 10-16-2016, 12:33 PM   #5
Strange Mud's Avatar
Rev has good advice...
Old 10-16-2016, 04:23 PM   #6
Revvv's Avatar
As scary as that is, it happens on occasion. Don't tell anyone, it may ruin my reputation.
Fuel issue? Ignition issue? jriccard 1979-1995 Mustang GT 7 07-04-2015 12:42 AM
clutch clutch... clutch Butch SVT Mustang 4 06-29-2012 03:53 PM
2000 V6 clutch/shifting issue audio75 Pre-2005 V6 Mustang 10 07-31-2010 11:41 PM
Clutch smell issue Rich_Guy 1996-2004 Mustang GT 7 07-14-2009 09:56 PM
clutch issue for the 56# time lol SpectorV Pre-2005 V6 Mustang 1 05-12-2003 07:00 PM
06:41 AM
