96 fuel rail removal problem - Mustang Evolution
Old 08-10-2008, 06:22 PM   #1
I'm in the process of digging down to what feels like the bottom of never to replace some gaskets.
I've taken off the upper intake manifold and am to the stage where the books says "remove the fuel injectors and rail assembly"...but I can't get the fuel rails off. There is a metal tube (I'm guessing this is what the Chilton's manual says is the "coolant bypass tube" that is "pressed in and not servicable") in my way.
I've pulled the fuel injectors out of their holes, but between that metal tube in the front and what appears to be called the "fuel pressure regulator" in the back, I can't move the fuel rails more than a few millimeters.
There is a flexible tube full of fuel running between the rails, but it really doesn't want to come off and I've torn part of the outer covering off trying to convince it to move.
Any hints?
Attachment 19611
shustwit is offline   Reply With Quote
Old 08-11-2008, 06:12 AM   #2
Re: 96 fuel rail removal problem
dont take the fule crossover tube off, they should just pull right out mayber with the help of a prybar, sometimes the orings dry up and get stuck but there is definitly a way to get them out, id have to be there to figure it out tho, may have to pull the regulator off
SimplyOrange is offline   Reply With Quote
Remove fuel rail for spark plugs? ajpturbo 1996-2004 Mustang GT 5 06-14-2010 07:55 PM
1995 convertable 5.0 temp/fuel gauge problem rwb223 1996-2004 Mustang GT 3 03-10-2010 12:55 AM
Little Alternator Removal Problem Nick388 1996-2004 Mustang GT 7 11-26-2008 07:45 PM
Fuel Rail Suggestions mspHtown General Mustang Discussion 3 11-19-2007 11:47 AM
split port swap fuel rail immenukka Pre-2005 V6 Mustang 4 08-09-2007 10:40 PM
03:13 AM
