adding a 4wire trailer lights - Help - Mustang Evolution
Old 08-11-2008, 11:58 PM   #1
My son and I want to take the bass boat with the V6 2005 mustang. I am adding a hitch. I really need help with the wiring of the 4wire. Could some one please help me. I know that I have to splice but I don't know where or the color combinations for the rear lights. All help will be greatly appreciated.
Thanks,
Kevin
yoyofruity is offline   Reply With Quote
Old 08-12-2008, 01:24 AM   #2
Send a message via AIM to VCS_SSSTANG
Re: adding a 4wire trailer lights - Help
VCS_SSSTANG is offline   Reply With Quote
Old 08-12-2008, 07:23 AM   #3
Spark Plug's Avatar
^^^^ my thoughts exactly.
Spark Plug Racing- "If it Breaks It Was Meant To Be Upgraded
2003 Dodge Ram HEMI
2008 Suzuki Kingquad 750 4x4
Spark Plug is offline   Reply With Quote
Old 08-12-2008, 07:45 AM   #4
DarkShadows's Avatar
That sounds entirely to red neck for me
March 2010 Mustangevolution Mustang of the Month 1st eva biatch!
DarkShadows is offline   Reply With Quote
Old 08-12-2008, 07:48 AM   #5
Old 08-12-2008, 07:59 AM   #6
Herbstang's Avatar
Damn !!!! Never have I seen a user live up to their screen name like you have only a yoyofruity would use a stang for towing
the voltage going to the tailights on mustang is not enough to run trailer lights.
taillights are controlled by a cpu and only 1 volt goes to the taillights.
You'll have to run relays with a power wire going to the battery and use this wire for the trailer lights
Old 08-12-2008, 08:08 AM   #7
you will probably need a wire tester or a wire listing~ im sure its been done so there should be some information with the hitch available to you if its made for your vehicle.
Old 08-12-2008, 08:14 AM   #8
The two things my 6 year old and I love to do is ride in the Stang with the top down and fish. So I am combining them.
I am hoping for a wire listing and any advice from anyone that has done this or would know how.
Thanks.
Old 08-12-2008, 08:28 AM   #9
Herbstang's Avatar
Read This routing a trailer wiring harness outside the trunk - Tundra Solutions Forum
Old 08-12-2008, 08:45 AM   #10
i cant say nothing thought, ill be putting a hitckh on mine too, but ill be hauling a small trailer with tools and race tires
Old 08-12-2008, 08:50 AM   #11
Herbstang's Avatar
:barf:
Old 08-12-2008, 09:42 AM   #12
like it was stated before, ther is not enough voltage to run a whole trailer,next thing, your rear shocks are extremely under rated for a bass boat..you will blow them out very quickly and probably over work your rear coil springs, where the car will sag in the rear even without the boat on it....i dont reccommend it
that being said, you can run them using relays and using the wires directly off of the tail lights as driver wires for the relays, gonna take 4 relays, a large power wire from 30 amp fused source and a good bit of wiring know-how.
SimplyOrange is offline   Reply With Quote
Old 08-12-2008, 10:10 AM   #13
Herbstang's Avatar
Mustang don't have a strong enough mounting point for a towing hitch. Safe towing is a chassis/ drivetrain issue. You need extra transmission cooling, extra electrical power, heavy duty brakes and heavy duty suspension. Mustang tow rating is about 1000lbs. you may have enough power to pull it. But but in an emergency situation you won't be able to stop.
Old 08-12-2008, 10:14 AM   #14
And it has a wiring harness in the hatch. 105 hp, I'm guessing it was to pull a red rider wagon.
Old 08-12-2008, 10:16 AM   #15
Herbstang's Avatar
Hey I still have my Red Rider Let give it a try Hopefully we won't do much body damage when it jack knifes
Old 08-12-2008, 10:19 AM   #16
i think a 5th wheel on the toof, and convert the bassboat to a gooseneck, that way it even distributes the weight on the suspension
rob>>>>>>>>>>>>>please remove it.
Old 08-12-2008, 10:24 AM   #17
Originally Posted by Herbstang View Post
:barf:
Well tell me where the hell im gonna stick 4 295 r comps inside that car with out fing up the interior? hitch would come off when not inuse anyway. im talking a SMALL trailer, sorry i do more racing than straight line
Old 08-12-2008, 10:33 AM   #18
Herbstang's Avatar
Rent a truck !!
Old 08-12-2008, 10:36 AM   #19
ok....im not gonna lie, i pull a camper with my car
Old 08-12-2008, 10:41 AM   #20
It's on the TODO list when I give the car a good once over and a tuneup.
Old 08-12-2008, 10:56 AM   #21
The boat and trailer will be under 1000lbs.
Can we get past that and help me understand the wiring?
Thanks
Old 08-12-2008, 10:59 AM   #22
Rent a truck !!
O so i guess the rest of the autox community that does it is wrong?
Old 08-12-2008, 11:05 AM   #23
Yes. If the rest of the community jumped off a bridge, would you?
Old 08-12-2008, 11:10 AM   #24
ok,it wont be bad if you know how to wire relays, just use the wires going to the bulb on the drivers side as the trigger power wires on the relay, ground the other side,and run a strong 6-9V power source through the relay for your main power,you have to do that for all of the 4 wires, its kinda difficult to explain without actually doing it,
if you need further information on wiring the relays, i can draw you a picture using paint, but its gonna be hilarious looking
Old 08-12-2008, 11:15 AM   #25
1. dont have money for a truck.
2. if i dont have money for truck i dont need a car trailer
3. renting truck and trailer is expensive and stupid if the only reason i need it is to haul tires and tools with my car.
4. i wouldnt expect you straight line people to understand anyway since yall are so one way minded. im not hauling 2 tires, its 4 and its not tires you would wanna ride on the street like street et's. here are the tires - Hoosier A6
so :fu2: to all you bashing bastards
off topic rob i thought you were gonna come in and talk to the servce department
Old 08-12-2008, 11:17 AM   #26
here ya go
Old 08-12-2008, 11:21 AM   #27
I am. It was busy yesterday, and I actually have a couple internal contacts here I should hear something about today. I will probably look to stop by tomorrow or thursday once I find out something on 2 positions with the state directly.
Old 08-12-2008, 11:23 AM   #28
go for it.
Old 08-12-2008, 11:41 AM   #29
Herbstang's Avatar
Damn you sure did a 360 form this post !!!!
Old 08-12-2008, 11:44 AM   #30
Herbstang's Avatar
Thanks
SimplyOrangeTPS has the best solution for you IMO get yourself a wiring diagram for the 05 and a volt tester Sorry can't be of more help Maybe the other sites you posted this question on will come up with a answer
Old 08-12-2008, 11:53 AM   #31
i was kidding and im not pulling boats. it is my car and it is his car so we can do what we want. i was refering not that is was a mustang towing, more that its towing a fishing boat. can you imagine a mustang launching a boat, i would imagine that to be a site to see.
Old 08-12-2008, 11:59 AM   #32
itll look like your sig when trying to pull it out
Old 08-12-2008, 12:06 PM   #33
Old 08-12-2008, 12:43 PM   #34
Herbstang's Avatar
I'm rubber and your glue whatever you say to me bounces off me and sticks to you
Old 08-12-2008, 01:01 PM   #35
I do feel about 7 yo with that comment. i just had a "choice" customer so im a bit unglued at the monent
Adding some modifiers, any adjustments back from iraq 1996-2004 Mustang GT 6 07-19-2008 09:56 PM
Binary Adding Machine.... bullitt482 Pictures and Videos 15 07-16-2007 05:40 PM
Adding an amplifier. matthews.stang Mustang Audio & Video 1 07-04-2007 02:32 PM
Adding another pony to the stable PureVenom The Bar 46 01-18-2007 11:14 PM
Might be adding a jeep to the family sonic04edge The Bar 0 02-14-2006 12:19 AM
02:24 PM
