Custom cams? - Mustang Evolution
Old 08-13-2008, 11:41 AM   #1
Scorpion1's Avatar
Custom cams?
Within the next few months I want to get a Super Six Motorsports top end kit to go with a 75shot and tune. However they only seem to offer regrinds or heavy lope cams. Id like to get something milder and more streetable. Does anyone know where I may find one? Or would the heavy cam be streetable for DD?
WiCK3D_SiX
Scorpion1 is offline   Reply With Quote
Old 08-13-2008, 11:53 AM   #2
Herbstang's Avatar
Re: Custom cams?
Comp Cams for one !!! Have you talked with Tom Y at Super Six about a cam ?? or try Delk Performance
Here's a good article about cams Cam Specs & Effects, duration centerline separation and lift
Old 08-13-2008, 11:57 AM   #3
Scorpion1's Avatar
Re: Custom cams?
great information, thanks!
WiCK3D_SiX
Old 08-13-2008, 12:09 PM   #4
Re: Custom cams?
we have a company in BR called cammotions, they will cut any cam you want.the lopy cam should be fine for the street.
SimplyOrange is offline   Reply With Quote
Old 08-14-2008, 12:05 AM   #5
Scorpion1's Avatar
Re: Custom cams?
would it be ok for stock heads/internals until I get the top end kit? I just dont wanna go bending valves or smashing pistons. I hear these are a PITA to swap, is it really that difficult or are these guys just bein wimps cuz the accesories gotta come off?
WiCK3D_SiX
Old 08-14-2008, 07:23 AM   #6
Re: Custom cams?
just run the biggest cam for a stock appliccation, the seller should know if itll fit or not.
Old 08-14-2008, 02:10 PM   #7
Herbstang's Avatar
Re: Custom cams?
Like the Man said it will work I'd wait to install everything at one time gaskets kit ain't cheap
Here'a link while it doesn't show how to install a cam It has enough info on V6 tear downs to give ya a idea
http://rpm-mustangs.com/pages.php?pageid=2
Old 08-14-2008, 02:24 PM   #8
Re: Custom cams?
i agree, id save the gasket money, and it lets you tune it one time overall.
Old 08-16-2008, 01:47 AM   #9
Scorpion1's Avatar
Re: Custom cams?
thanks for all the help. Just out of curiousity what kind of gains would I be looking at from a cam on stock heads?
WiCK3D_SiX
Old 08-16-2008, 08:10 AM   #10
bbunt302's Avatar
Re: Custom cams?
Not much. In general, stock cams are pretty well suited for the flow of the stock heads and intake. A cam is pretty much a waste of time and money until you have an increase in air flow to make use of it. Your money is better spent elsewhere.
Here's a great article from another custom cam grinder, Buddy Rawls:
Cam Truth
Going with the biggest cam you can run is definitely not the way to do it. Also, any time you change a cam you should check piston to valve clearance. Every engine is different and a cam that may not cause any problems on one could on another.
Scary stuff.
Old 08-18-2008, 04:57 PM   #11
Send a message via AIM to VCS_SSSTANG
Re: Custom cams?
realistically about 10-15rwhp with everything stock... It would be beneficial to at least have ported intakes.
VCS_SSSTANG is offline   Reply With Quote
Old 08-20-2008, 05:55 PM   #12
Send a message via AIM to white95v6
Re: Custom cams?
yea a custom cam with stock parts might get 10-15 hp with a tune.
with the top end parts it would realy wake your car up like 60hp with all the parts that work well together.
Matt
The First and Only 9 Sec Production Based V6 Stang!!,First over 500rwhp,First and only over 600rwhp
60ft-1.42,1/8th mile-6.25@111mph,1/4 mile-9.83@136.65mph
Sponsored by:
WWW.DELKPERFORMANCE.COM
white95v6 is offline   Reply With Quote
New Cams? iwannagofast 1996-2004 Mustang GT 18 05-07-2010 03:30 PM
Pi cams ?'s 1995procharged 1996-2004 Mustang GT 1 09-07-2009 12:16 AM
4.6l Cams Black00GT 1996-2004 Mustang GT 14 11-17-2008 09:19 AM
anyone have any cams out there? Zim Mustang Parts for Sale and Wanted 5 03-05-2005 06:59 AM
explanation of 1.73/1.8rr's with/without custom cams? tire Pre-2005 V6 Mustang 5 12-29-2003 11:18 AM
09:58 AM
