stupid bolts won't come out...advice? - Mustang Evolution
Old 08-13-2008, 03:21 PM   #1
Anyone have any advice for getting the bolts out of the head? I'm on my second impact (the first one was a wimp, so I went and got a better one) and I still can't get 3-4 of the stupid things out.
And what do you do about the one in the back on the driver's side that's blocked by the brake booster? I thought about taking the booster off, but I can't get to the bolts for it without taking off the brake pedal. Sheesh. To be sooo close...
shustwit is offline   Reply With Quote
Old 08-13-2008, 04:31 PM   #2
Send a message via AIM to VCS_SSSTANG
Re: stupid bolts won't come out...advice?
what are you doing exactly?
VCS_SSSTANG is offline   Reply With Quote
Old 08-13-2008, 06:04 PM   #3
...taking off the heads...we decided to have them checked out at the shop before putting it all back together. (I tore it all apart because the head gasket was trashed and needed replacing.)
Old 08-13-2008, 07:22 PM   #4
Racin02GT's Avatar
Send a message via AIM to Racin02GT
Sometimes a long breaker bar can do the job that an impact cant try to get a bar as long as possible
Racin02GT is offline   Reply With Quote
Old 08-13-2008, 07:29 PM   #5
Scut95's Avatar
spray them with penetrating oil and let them sit for a while....even over night and then try an impact or breaker bar to get them out....with the one in the back, can you use swivels and extentions to get at it? without seeing it, its tough for me to visualize whats happening back there
Old 08-13-2008, 09:06 PM   #6
what engine are you doing this to? i usually drop the k menber for a head swap.only takes 15-30 min and you have all the room you need, and i use a 3ft breaker bar to break them loose then a 1/2" impact
SimplyOrange is offline   Reply With Quote
Old 08-13-2008, 09:09 PM   #7
Judging by the forum...I'm going to guess it is a V6....prolly a 3.8L.
Old 08-13-2008, 10:48 PM   #8
Kiljosh's Avatar
I know of this bolt. It is a *****.
I did a whole install using only a breaker bar, no impact gun at all.
I used a U-joint with a 1/2" socket on a 3 foot breaker bar. Not one bolt gave me trouble. The key is quick bumps. Dont just push on the bar with all your might. Hit it suddenly.
Old 08-14-2008, 06:25 AM   #9
good observation, i missed that
Old 08-14-2008, 01:57 PM   #10
bbunt302's Avatar
This is the best way to do it. Use leverage to your advantage and put on the longest breaker bar you can find. Use quick taps of pressure instead of a constant pressure so you don't break the bolts.
Scary stuff.
Stage 8 bolts, but no bracket bolts? CreationNation 1979-1995 Mustang GT 1 04-13-2009 10:00 AM
Stupid Stupid Bonds bluemustang The Bar 8 02-07-2007 09:39 AM
desire advice... stock investment type advice... dark The Bar 4 04-23-2006 06:07 PM
Where to find these Bolts at? drummerstang98 The Bar 5 08-18-2004 10:14 AM
What nuts and bolts do I need? njstang97 Pre-2005 V6 Mustang 4 02-17-2004 07:19 AM
08:13 AM
