01+3.8 Throttle Body experts in here !!!! - Mustang Evolution
Old 01-06-2004, 12:45 AM   #1
i purchased a half shafted and polished TB. teh problem is that it does not match up with my 2002 v6 TB. the one i got is a 01+ TB but on the butterfly valve mine has one little hole in the center and the letters C & G stamped on it. the one i purchased has 2 little holes and the letters D & D stamped on it. i also need to buy a new Throttle Position Sensor (TPS) for the one i purchased but now i don'e know exactly what i have. any help here ?????
OldManNewHotrod
http://images.cardomain.com/installs.../266659_16.jpg
Mods Made Thusfar:
17x9" Black Bullet rims w/Khumo ASX's 275/40/17
GT Take Off Dual Exhaust w/Dynomax Turbo's
K&N Performance Intake (FIPK)
ASP UDP
Flex's Phenolic Intake Spacer
So Cal Diablo Chip
373 Gears with Tlock
crabmeat is offline   Reply With Quote
Old 01-06-2004, 10:56 AM   #2
2002 is 01+
1998 Subaru Legacy L Sedan
New Hottness
1999 V6 5-speed
14.6 @ 95 w/ 2.22 60'
Wrecked
stangin99 is offline   Reply With Quote
Old 01-08-2004, 08:40 AM   #3
00-01 is the same TB. 02+ is different. The TPS is the same on all TB's 99+.
Laser02 is offline   Reply With Quote
Old 01-09-2004, 03:23 PM   #4
Ah, so the 02s have the two holes for in the plate like the 99s? Odd that ford would
change back and forth. You don't need a new TPS, just reuse the stock one you have. The throttle cable linkage is correct, right?
-Mik
Redlined Performance Mustangs
Cylinder Head / Intake Porting, Camshafts, Pistons, Cold Airs/Pulleys
www.rpm-mustangs.com
http://rpm-mustangs.com/pictures/KEcrank.jpg
mikael is offline   Reply With Quote
Old 01-10-2004, 02:57 AM   #5
Dom
Dom's Avatar
Send a message via AIM to Dom
Pretty much.
Should i get a throttle body? blackonblack Pre-2005 V6 Mustang 21 12-07-2009 07:21 AM
throttle body ? wvstang5.0ho 1979-1995 Mustang GT 16 07-29-2008 10:48 AM
throttle body sonicpony Pre-2005 V6 Mustang 2 09-09-2007 12:23 AM
Throttle Body Scut95 1979-1995 Mustang GT 4 07-01-2005 10:50 AM
throttle body Murph00 Pre-2005 V6 Mustang 5 11-26-2004 11:43 PM
06:17 PM
