What do you engine guys think about that 4.0l for the 2005? - Mustang Evolution
Old 01-06-2004, 02:04 AM   #1
Send a message via AIM to ASSEMbler
What you guys think of the 4.0? The blockis the same as the bronco but bored I hear.
SIG REMOVED FOR THE PRUDE
ASSEMbler is offline   Reply With Quote
Old 01-06-2004, 02:42 PM   #2
RGR
Send a message via AIM to RGR
Re: What do you engine guys think about that 4.0l for the 20
I"m still not sure which 4.0 it is!!!
I had a good idea it would be the 4.0 SOHC
(hot ticket!!!) then a very good source in the
industry said it was just the regular 4.0 OHV and
now I saw again where it is the 4.0 OHC...
Either shortblock is basically the same, and it will
be nearly identical to the Explorer (bronco) engine
of the corresponding type. They have both too...
There will be millions of JY pieces if it is the
OHV but fewer OHC parts. But OHC makes ~50 more HP
Overall it is a good move except that it is not a 90* V6
but a 60* V6... totally different engine than we have now.
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 01-06-2004, 05:02 PM   #3
Bronco block
Well for says OHC.
It's the same as the bronco block.
Have you looked at the bronco block? How is the block thickness?
The main problem with our block is it can't take compression too well.
It can be a 60 degree, but is it's a thicker truck block, boost the hell out of
it.
Old 01-06-2004, 07:15 PM   #4
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
its a 4.0 sohc.
with 202hp and whatever tq.
I read the mag. today with the stats just forgot all them.
I dont know which platform their using. But iam glad they went to a 4.0 rather than a 3.0
Rellik is offline   Reply With Quote
Old 01-06-2004, 08:27 PM   #5
Dom
Dom's Avatar
Send a message via AIM to Dom
Well, aftermarket will take 10 years to pick up on it.
244ci if anyone is wondering.
Old 01-06-2004, 08:38 PM   #6
Rick0636's Avatar
If they haven't picked up on it by now, they never will, its been around for years and years, its basically a bored and stroked 2.6L that used to be in the old Capris and Mustang IIs way back in the mid 70s maybe even before that in the Capris and others. Its probably already about stretched to its limit for performance however, but, it will make a little Ford Ranger SCREAM though, lol.
Old 01-06-2004, 08:40 PM   #7
Rick0636's Avatar
Also the OHV and the sohc engine is the same engine, they just changed it around and made it into a sohc.
Old 01-06-2004, 09:12 PM   #8
Dom
Dom's Avatar
4.0-liter SOHC V-6 – Anything but Basic Performance
With technologies like electronic throttle control, traction control and an available five-speed automatic transmission, the base Mustang’s new 4.0-liter SOHC V-6 powertrain is anything but basic. And with 200 horsepower and 235 foot-pounds of torque, the V-6 engine offers real Mustang performance at a more economical price.
The 4.0-liter V-6 offers improved NVH, higher power output and a more compact package than the previous Mustang’s 3.8-liter pushrod V-6. It features low-profile heads with single overhead cams driven by a slave shaft mounted in the "V" of the engine. This results in a lower overall engine height than a conventional overhead cam setup.
As in V-8 applications, a new composite intake manifold was developed specifically for duty in the Mustang. The 4.0-liter V-6 also gets a unique camshaft grind, new tuned-length exhaust manifolds, a new flywheel and an oil pan. In addition, Mustang engineers designed an enhanced fuel injection system with reduced evaporative leakage, a new EGR system and revised cooling circuit for the 4.0-liter V-6.
Key noise-reducing features of the 4.0-liter SOHC V-6 include a girdled crankcase for increased strength and rigidity, a dual-mode crankshaft damper, coated skirt pistons, optimized bearing clearances and isolated composite cam covers.
Research with current and potential customers played a role in achieving the sound quality buyers expect from a Mustang engine. Listening studies were conducted with current and potential Mustang owners to determine precisely what engine sounds were "powerful." The resulting sound reinforces the American muscle-car personality of the 2005 Mustang.
- StangNet.com
Old 01-06-2004, 10:22 PM   #9
thats not really the same anymore. Maybe the shortblock is old but everything above that is different.
You can't really say a pushrod motor and OHC motor are the same. Its to HUGE a difference to even be considered.
1998 Subaru Legacy L Sedan
New Hottness
1999 V6 5-speed
14.6 @ 95 w/ 2.22 60'
Wrecked
stangin99 is offline   Reply With Quote
Old 01-06-2004, 11:59 PM   #10
Rick0636's Avatar
Excuse, same basic block, has been since the 2.6L used back in the 70s, that was my point. Of course they have changed around, they bored, stroked it, then they changed the heads, they made it into an overhead cam engine, there have been tons of changes, but its still basically the same old block, with tons of modernization and changes, of course. Like I also said, its pretty much stretched to its limit, I am not sure how much souping up it can take and still be sound.
Old 01-07-2004, 12:04 AM   #11
Rick0636's Avatar
Its no different than Ford does with its V8s, they took the 221cu. in V8, bored it stoked it, whatever, and made the 260, 289, 302, 351W, yes the windsor does have some different heads and maybe deck height of the block, but still cut from that same old basic 221 block and modified. Chevy has done more or less the same thing, 265, 283, 327, 302, 350, small block 400, all from the same old block, and you can bet they are probably still pouring blocks in that same old mold at GM now.
Old 01-07-2004, 06:53 PM   #12
Dom
Dom's Avatar
Congrats. You figured out the the main differnce between all engine. The only real difference is big block or smalll block.
Old 01-08-2004, 04:54 AM   #13
Man I wish they had balls and went with an inline six.
Old 01-12-2004, 08:37 PM   #14
I read it's suppossed to put out around 200hp! At least it's something better to work with. And I think that Ford should have made an OHC v6 for the Mustang a long time ago.
widowvirgin is offline   Reply With Quote
Old 01-12-2004, 08:40 PM   #15
Klamdogg06's Avatar
Send a message via AIM to Klamdogg06
I bought my 2003 v6 stock and it came with around 190 give or take a few
Stupid Neons....Always pulling out infront of me
Can't they see I'm hauling *** right now!?
Klamdogg06 is offline   Reply With Quote
Old 01-12-2004, 09:53 PM   #16
hi newb
New Hottness
1999 V6 5-speed
Wrecked
Old 01-14-2004, 03:43 PM   #17
Send a message via AIM to Outk4stV6
hi newb
haha now that is damn funny
Silver 2000 V6 auto w/ 17" silver cobra rims, 20% tint all around, mach 1 grill delete, cai, halfshafted and ported TB, P&P upper intake, dual flow 40s w/ pacesetter h-pipe w/ gt take-offs
representin' www.sacstangs.com
Outk4stV6 is offline   Reply With Quote
Old 01-14-2004, 03:49 PM   #18
Klamdogg06's Avatar
Old 01-14-2004, 03:57 PM   #19
Zim
You want to **** me?
Zim's Avatar
dont rag on the guy cmon guys. Klam, thats 190 bhp (at your crank) you wont see close to that at the rear wheels
I like toys
Old 01-14-2004, 03:59 PM   #20
Dom
Dom's Avatar
Rather have the V6 so I can say I have a V-engine.
Old 01-14-2004, 04:01 PM   #21
An inline would be a better torque producer...so I hear.
All pigs are useless!
Old 01-14-2004, 04:34 PM   #22
Klamdogg06's Avatar
hmm
Old 01-14-2004, 04:35 PM   #23
Klamdogg06's Avatar
i tried to find out how much hp it has but all it said was 190, if thats at the crank how much is at the rear wheels
Old 01-15-2004, 12:26 AM   #24
Send a message via AIM to Jarrell
I don't like it at all. not enough power for the displacement increase. imo
If ur going to do somthing, do it right.
Jarrell is offline   Reply With Quote
Old 01-15-2004, 02:47 AM   #25
tire's Avatar
Send a message via AIM to tire
an inline engine would be easier to work with, one header, one head, it'd be ohc of ocurse though.
tire is offline   Reply With Quote
Old 01-15-2004, 02:49 AM   #26
tire's Avatar
~150-160. don't worry, most members here wont' treat you different just because you're new. yours has 193, but its just because of the irmc (intake runner man.... don't worry about it, that'll come later ) welcome to the site.
Old 01-15-2004, 08:06 AM   #27
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
I'm disgusted that they were only able to squeeze a whole 7 HP out of that kind of displacement increase and making it overhead cam. Come on, the 350z puts out 287 from a 3.5. 200 is pitiful. :no:
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 01-15-2004, 08:08 AM   #28
you guys are missing the whole point of the "base model" mustang.
if someone wants performance mustang, they would buy a GT, or a cobra.
Ford see's the v6 as a cheap sporty looking car, so they dont care to make much performance out of it.
And the 2004 was 193hp,
and the 2005 is like 207hp so you gained a little bit more.
lol
Old 01-15-2004, 08:16 AM   #29
BlueDonkey's Avatar
and Nissan charges $10,000 more for it. If you were willing to give Ford $10000 more for your 6-cylinder, I'm sure they'd hook you up
BlueDonkey is offline   Reply With Quote
Old 01-15-2004, 08:18 AM   #30
Danger Dude's Avatar
Hell 3500 for a supercharger a be at 350Z performance
Old 01-15-2004, 08:33 AM   #31
BlueDonkey's Avatar
exactly! Aftwerwards, you can spend the rest on suspension and beer :yes:
Old 01-15-2004, 04:07 PM   #32
Klamdogg06's Avatar
like this one...it will be mine!
8) http://www.rpmoutlet.com/musv6ati.htm
Guys need help.. going to get new engine.. need advice Skyes97Stang Pre-2005 V6 Mustang 9 11-28-2009 12:35 AM
For all you guys that think T-tops would look good on the 2005+ Stangs SilentNoise 2005-2010 Mustang GT 44 06-05-2008 08:41 PM
Engine noise from COLD engine 03GreyMach1 1996-2004 Mustang GT 10 03-14-2008 07:40 PM
engine swap 1989 to 1992 4 cyl engine dannyc1992 General Mustang Discussion 0 02-08-2008 01:59 PM
Big Problem Guys- Engine shuts down! DMAC Pre-2005 V6 Mustang 7 12-03-2007 10:29 AM
03:49 PM
