Engine problem, need expert input here! - Mustang Evolution
Old 01-06-2004, 09:10 PM   #1
Send a message via AIM to ASSEMbler
I will be pulling the car to a stop.
or
Be pulling up to a light.
As the car slows, it has a slight shudder. The electric, lights, all dim.
Can this be signs of a slipping belt, or a failing/binding alternator?
I have no voltage fluctuation.
It's obviously related to something on the accessory belt as it
doesn't happen at speed.
Kevin
SIG REMOVED FOR THE PRUDE
ASSEMbler is offline   Reply With Quote
Old 01-06-2004, 09:34 PM   #2
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
when that happens do u ever feel a difference in your power steering?
Check the belt, check the tension.
It could be the alternator dieing.
Rellik is offline   Reply With Quote
Old 01-06-2004, 09:36 PM   #3
There's no noticable power steer, but load devices like windows do slow down.
Old 01-06-2004, 09:40 PM   #4
BlueDonkey's Avatar
When you say you have no voltage fluctuation, do you mean the in-dash voltage meter? The dash instruments aren't known for their accuracy....
Better to measure it with a meter.
BlueDonkey is offline   Reply With Quote
Old 01-06-2004, 09:42 PM   #5
well lights dim, gauge looks the same.. That's proven..
There is no belt squeal. How would I test the alternator?
Old 01-06-2004, 09:48 PM   #6
BlueDonkey's Avatar
check the voltage between +12V and chassis ground. I think a working alternator should be running at +13.5V. May not be right. But alternator needs to run more than 12 to charge battery.
OR
remove the alternator and take it to PepBoys/Autozone or other parts place. They should be able to check it out.
As an aside, to those who know, would it be possible that it is putting out the correct voltage, but isn't putting out enough current?
Old 01-06-2004, 10:13 PM   #7
have autozone or some place similar run a test on your electrical system.
1998 Subaru Legacy L Sedan
New Hottness
1999 V6 5-speed
14.6 @ 95 w/ 2.22 60'
Wrecked
stangin99 is offline   Reply With Quote
Old 01-07-2004, 04:33 AM   #8
Danger Dude's Avatar
Actually a weak cell in the battery could also be a problem. Like stangin99 said go get the electrical system checked. A weak battery can cause alot of grief.
Old 01-07-2004, 05:26 AM   #9
When you have those moments when the lights go dim and ect. Does the Battery Light come on in the dash?
Old 01-07-2004, 11:38 AM   #10
Zim
You want to **** me?
Zim's Avatar
yeah check and make sure your battery is full of water too...
I like toys
Old 01-07-2004, 11:21 PM   #11
tealstangman's Avatar
Region: Nevada
Send a message via AIM to tealstangman
ya
Ryan
2002 red GT mustang
GO:Flows, BBK lowering springs, KYB struts & shocks, Mac straightshot CAI, SCT chip and tune, Accufab Plenum 70mm, Motive 4.10's
Show:18x10 & 18x9 Bullitt Deep Dish Chrome Wheel's
295/35/18 & 265/35/18 Michelin Pilot Sport PS2's
tinted windows, billet grill
tealstangman is offline   Reply With Quote
Old 01-08-2004, 04:52 AM   #12
The battery light does not come on at all. Is there a way to test the battery without pulling it from the car? It's COLD outside.
Old 01-08-2004, 05:29 AM   #13
well you can go to a auto store or walmart and by a hydrometer. It is a plastic tube with a scale and a bulb at the top and you draw up the fluid in each cell and it will tell you if a cell is dead or not. But the best way is to drive up to autozone and act stupid and they will take it out for you and test it. But you live in NJ they might tell you to GO GET SCREWED !!!
Old 01-08-2004, 08:14 AM   #14
sears does diehard service for 12.99
tests alternator, how it charges, battery, starter, some other little things but its 12.99 not free like some other places.
Old 01-08-2004, 08:15 AM   #15
That is not a bad deal Sears has for a electrical system check
Old 01-08-2004, 10:11 AM   #16
Send a message via AIM to 232SCstang
does the tach reading stay consistent or smooth? i.e. do the rpms fluctuate up and down? My guess would be the alternator. Take it to an auto zone or somethin and have them put a meter on it. Corey, I could be wrong, but I believe the charging system is supposed to be at 14.5 or .6 but I might be wrong. My amp for my stereo tells you the voltage of the cars charging system and mine always has a consistent 14.4-14.7.
1988 Ford Mustang LX
306ci 5 speed
1990 Isuzu Pickup
2.3L 5 speed
1990 Acura Integra
1.8 5 speed
All vehicles in color of text k:
232SCstang is offline   Reply With Quote
Old 01-08-2004, 10:18 AM   #17
As long as it does not go below like 13.5 you are ok. A dying battery cell or altenator or even a dammaged battery cable
Old 01-08-2004, 04:06 PM   #18
Re: Engine problem, need expert input here!
or
Kevin
First of all is your trans. manual or automatic. In the meanwhile check the alt. belt for proper tension and also the pulley to make sure it is tight and make sure all electrical connections are tight and all grounds are tight, then check output with a voltmeter if you have one. The voltage output should be between 13.1 and 13.5v at idle. Then have someone rev the engine and your output should go up to around 14.3v. If you see no change in the voltage then your alt. is no good. If voltage is good check current with with an ampmeter or dmm. The specifications should be on the alternator. If that is good then load test your batteries with a load tester if you have one. If you have an auto. trans. the problem could be in the trans. but I'm not sure. Also test your sensors, such as your maf, iat, tps and especially your ivs. Is your acceleration smooth or does it do the same as when you slow down? When was the last time you changed your fuel filter?
widowvirgin is offline   Reply With Quote
Old 01-08-2004, 07:26 PM   #19
It's an auto with a kit. The tach stays the same, everything electric goes dead for a sec that is electric, I mean it's an eyeblink. And ONLY in those two situations. But, even at decent rpms, the radio and other devices cut off if one big load like the windows are used.
Acceleration is very good, I only have a CAI , shift kit and exhaust and I can smoke the tires (18x9) in the back. Mind you it's ONE tire (teh one wheel spin = gay) as I bought rims instead of the 8.8..
I'll take it to autozone, they'll test the battery. It's the original POS battery I got in the car.
Since I live in a city environ, I get the works done at a lube place, so all the filters and fluids are consistantly changed on a regular basis.
I'll get back to you after tomorrow when I get the alt /batt checked.
Old 01-09-2004, 07:47 AM   #20
Its most likely the alternator. I had similar problems, checked everything couldn't figure out what it was. I even had my system checked 3 times at different Autozones and they told me it was fine.
Well, one day I replaced my alternator and it hasn't happened since
New Hottness
1999 V6 5-speed
Wrecked
Old 01-09-2004, 09:32 AM   #21
check to see if a terminal connection on the battery is loose.
if either one has any play at all it could be that....
Old 01-10-2004, 09:12 AM   #22
[quote="ASSEMbler"]
haha, lol. Well if your battery light doesn't turn on in your dash and you say everything electrical begins to goe dead when you start using other accessories, then I think you have a bad ground. At my job a similar problem would happen. When the driver would turn on his headlights or any other accessory his engine would turn off. When the problem was looked at it was simply a bad ground cable.
Old 01-21-2004, 10:57 PM   #23
You know how many points the car is grounded at! ha. this sounds like a lot of future fun.
Old 01-22-2004, 03:55 PM   #24
oaktonarcher's Avatar
Send a message via AIM to oaktonarcher
yea i have this probleme to. when im at a light some times ill press the switch to roll up my window and my car ill shudder. it also happens when i adjust my electric seats. and my cars only like 6 months old. should i take it back to the dealer?
Delta Sigma Phi
building better men since 1899
You still have a quote in your sig from a guy that hasn't signed in in almost 2 years
www.DeltaArmsCo.com
oaktonarcher is offline   Reply With Quote
Old 01-22-2004, 03:57 PM   #25
yea I would take it back if its still under warranty. You paid for a warranty use it
Old 01-22-2004, 04:10 PM   #26
The car will do that...they'll just look at you and say there's nothing they can do about it. I had someone else point out that on his 02 it shutters cruising at about 35. I noticed the same thing. There are a few small things ford can't do anything about and will feed you a bunch of bs until you leave them alone..
Old 01-22-2004, 06:09 PM   #27
Amen to that. BS upon BS to no end. :no:
Tin Kicker
Peace, love, 'Stangs.
2003 White 3.8/Auto/No mods YET. Now considering what massive horsepower mod to do first.
Tin Kicker is offline   Reply With Quote
Old 01-22-2004, 07:39 PM   #28
I'm sitting at 35,600 and I'm going to make a list of stuff I want fixed and carry it up there. I haven't moved my car all week until I get time to carry it up to ford lol. Not even going to move it this weekend.
Old 01-25-2004, 11:42 AM   #29
Yea my car only has 4000 miles on it : y do I have problemes with it already.
im taking the car back to the dealer to see what bs they give me. thanks for the help
Delta Sigma Phi
www.DeltaArmsCo.com
04' 3.9 Musatng engine problem video!!! Zebs5408 Pre-2005 V6 Mustang 5 02-04-2010 06:40 AM
I need a computer / electronic expert upton7 The Bar 6 06-19-2009 05:58 AM
Big Problem Guys- Engine shuts down! DMAC Pre-2005 V6 Mustang 7 12-03-2007 10:29 AM
News update on engine problem Danger Dude Pre-2005 V6 Mustang 14 08-11-2003 01:54 PM
04:47 AM
