Putting 96' breaks on 00' mustang? Hydroboost? - Mustang Evolution
Old 11-07-2017, 10:55 AM   #1
Exclamation Putting 96' breaks on 00' mustang? Hydroboost?
Are the 96' breaks hydroboost? If they are, and i have a doner car, can i install them on my 00' mustang?
mustang77 is offline   Reply With Quote
Old 11-07-2017, 11:19 AM   #2
jkeaton's Avatar
You referring to the hydroboost unit only, or the entire brake system?
03 GT Convertible, 5-speed
07 V6 Coupe
jkeaton is offline   Reply With Quote
Old 11-07-2017, 11:31 AM   #3
96-04 is Hydroboost but the 96-98 GT front calipers are garbage. 99-04 GT is dual piston and then the 94-04 Cobra/Mach/Bullitt brakes are the best from those years.
Old 11-07-2017, 01:16 PM   #4
So like i said, i have a 00' base mustang, the doner car is a 96' GT (forgot to mention the GT part).
jkeaton: I am refering to the entire break system, just swap them out. Are they compatible? Because iv seen them changed/installed (not sure if it was a mustang i might add) and somebody had to go in with a dremel and widen the hole the master cylinder unit goes in to bolt down to the car. Will i have to do this? As well as replace the lines?
Thanks
Old 11-07-2017, 02:15 PM   #5
Revvv's Avatar
Brakes, not breaks. You do not want your brakes to break. Big difference.
2013 mustang 5.0 breaks drive shaft 2011fastford 2011-2014 Mustang GT 22 02-13-2015 02:46 PM
How many horsepower is my 1984 mustang putting out? Sahm 1979-1995 Mustang GT 5 12-20-2011 11:36 AM
Is the 65 mustang a car that when it breaks down it is hard and expensive to fix? Jayar General Mustang Discussion 6 03-12-2010 11:05 PM
HELP, I have a 1996 Mustang V6 and am putting in a 1995 V6 trucky12 Pre-2005 V6 Mustang 3 09-15-2009 04:18 PM
04:00 AM
