M112 Build Questions - Mustang Evolution
Old 01-10-2018, 11:52 PM   #1
2000v6stang's Avatar
Region: Iowa
So I got my short block back from the engine shop and I just had some questions on some of the components of the m112 build.
First, off can I just use the 39 pound cobra injectors part number 2R3V-B5A (bosch ev6 i believe).
Second, I read that the 5.0 lifters were the same as the 3.8s so I was looking at Ford Racing OEM lifters ( M-6500-R302 ) will these work and are they any good or should I do another brand or Motorcraft? it says they are a 1/16" taller than factory but are supposed to be OEM but i guess the height of the lifter its self might not matter.
Next, will the SVT Fuel pump ( PFS204) be enough for the set up if I end up running 10 PSI also do I need just the pump its self or the whole assembly?
I was looking at replacing my oil pump should I do motorcraft or would Melling ( M246) be good? On rock auto the Melling and Sealed power say "standard volume and pressure, works as high volume on this application" I am not sure what that means so should I run that pump or not?
Blacking it out, MAC duel exhaust, SR CAI, Performance Automatic shift kit. And a long build list wrecked in July '14
2000v6stang is offline   Reply With Quote
4.6 Build Questions Hellish Horse 2005-2010 Mustang GT 46 05-14-2015 07:38 AM
few questions on my build jeMstang Pre-2005 V6 Mustang 10 02-07-2014 07:25 AM
2v build questions taylor98gt 1996-2004 Mustang GT 2 09-18-2012 07:25 PM
19Delta's M112 Build 19Delta Pre-2005 V6 Mustang 104 04-06-2010 02:05 PM
4.2 build questions Zebs5408 Pre-2005 V6 Mustang 0 03-19-2010 05:37 AM
02:56 PM
