I need help deciding what dual exaust to put on my 6 cyl. - Mustang Evolution
Old 08-20-2008, 05:24 PM   #1
I am about to put duals on my 2000 ford mustang. And I have a couple options i can do. 1 I can do an H pipe off the cats and do a offbrand of a flowmaster and go straight down without any tailpipes. 2 or i can not do an H pipe and go straight out the back of the cats and put thost offbrands on it and have tailpipes. But which one should i do? Because I heard if i dont have tailpipes it will be really loud up in my car. So do H pipes really make that big of a difference?
Prest_2890 is offline   Reply With Quote
Old 08-20-2008, 07:30 PM   #2
1234's Avatar
Re: I need help deciding what dual exaust to put on my 6 cyl.
Id go with tail pipes. It might look better. You want advise on exhaust wait for Kyle to chime in i heard he has a killer exhaust system on his v6
Old 08-20-2008, 08:31 PM   #3
Kyle is offline   Reply With Quote
Old 08-20-2008, 08:31 PM   #4
Old 08-20-2008, 08:34 PM   #5
1234's Avatar
They we right it sounds awesome.
Old 08-20-2008, 08:37 PM   #6
thanks man
Old 08-21-2008, 03:12 AM   #7
i heard it in person, and it definitely doesnt sound like your average six.
96 GT- Who knows what's in it.
Old 08-21-2008, 07:12 AM   #8
Herbstang's Avatar
Damn Klye !! Rejected or not your exhaust sounds great !!!
Old 08-21-2008, 08:02 AM   #9
the best thing to do is buy a dual exhaust adaptor and have it welded on for starters, why???? so you dont weld the exhaust on to turn your Y to an H and thus lose the ability to remove the exhaust if you need to~ its all welded and will have to be cut
After this you can bolt up any catback for a gt mustang you wish~ you just need to change the exhaust hangers since you dont have bumper cut outs. Dont go to loud, v6s dont sound good due to the even fire setup they have... they are ok till about 2500 rpms then its all down hill from there. Mellow tone is the best way to go, louder is not always better.
Old 08-21-2008, 09:59 AM   #10
So what did you have put on your mustang to make it sound like that?
Old 08-21-2008, 10:14 AM   #11
on mine? i have an o/r x pipe running into flowmaster 40s
Old 08-21-2008, 10:27 AM   #12
Ive heard with the x pipe it heats up your trans. really bad though.
And I dont have enough money to go with the flowmaster but there is an aftermarket brand of a flowmaster that i am putting on it. So i think i am just going to do the H pipe and then instead of getting tips on it just bend it down over the axle.
Old 08-21-2008, 10:39 AM   #13
X pipe heats the trans? Wow, first time I've heard that one. The only difference between the X and the H is the shape it makes where they join together, so, if an X heats your trans, then so will an H. Just an FYI.
Old 08-21-2008, 10:40 AM   #14
1234's Avatar
Thats probably not gonna sound to good. If anything just wait a bit and do it right.
Old 08-21-2008, 01:47 PM   #15
Herbstang's Avatar
We can add that one to Urban Myths
Pic of Y pipe and X Pipe --- Whoever told you it will cause your trans to overheat Don't let them touch your car
Old 08-21-2008, 02:34 PM   #16
an h pipe is supposed to give a deeper sound. but on a v6 an o/r h pipe (or at least the setups i have heard) sound too much like a truck to me, as well as pretty choppy. the choppiness can be eliminated alot by just using a chambered muffler (ie flowmaster)
i've had about 6 or 7 different exhaust setups on my car, my current setup is what i like the best. not too loud, not too quiet. nice, relatively deep, consistent hum at idle and not too raspy or "airy" when you lay into the throttle.
if you got the cash to drop on it though, i have also heard a v6 with a borla xr1 catback on it. i think he might have had the stock y pipe on it though but it sounded pretty good too.....its kinda pricey though
Old 08-22-2008, 08:04 AM   #17
I had the stock Y pipe and just flowmaster 40's (cut the Y pipe after the cats and made it into two pipes aka true dual exhaust, then ran it out to tips using 2.25 inch pipe (no bigger)
Old 08-22-2008, 05:51 PM   #18
that was one of the setups i had, just with different mufflers. i noticed that i got horrible gas mileage like that. did you?
Old 08-23-2008, 06:15 PM   #19
Question Re: dual exaust on v6
Saw this a little while ago . . . .
"Another tactic would be to fit a true dual exhaust, as V-6 engines prefer two separate three-cylinder exhaust systems with no H or X crossovers.
While more expensive, such systems can definitely aid power with forced induction and often sound more V-8-like than rasp-can given the Mustang's generous six-cylinder displacement. It just depends on what you're listening for." 5.0 Mustang Magazine - Online
Would you please elaborate? Thanks.
Vaya con Dios.
4thMustang is offline   Reply With Quote
Old 08-23-2008, 10:46 PM   #20
What o/r x pipe was that? The pypes one? Im guessing you just had a shop fabricate the rest? How much did that setup cost about?
Dark04ShadowV6 is offline   Reply With Quote
Old 08-24-2008, 12:31 PM   #21
it was the pypes o/r x..........i got that for 200 i think, the mufflers for 30, 110 for the magnaflow ss tips, and 160 in labor for it all
Old 08-24-2008, 01:23 PM   #22
1234's Avatar
^^does your x pipie fit right? like as in close to the underside of the car.
Old 08-24-2008, 01:27 PM   #23
Old 08-24-2008, 01:29 PM   #24
1234's Avatar
So i need to modify mine. It hangs about 4 inches lower than its suppost to.
Thanks for the pic.
Old 08-24-2008, 02:05 PM   #25
Im really thinking about getting that setup. Either that or the mac catback... Do you have any videos of you reving it or drivebys? Also do you thinkit would sound good with just a cai as the only other performance upgrade?
Old 08-24-2008, 04:21 PM   #26
based on what i've heard i would go with i would go with flowmasters instead of mac
here's a track video of the exhaust
Old 08-24-2008, 06:54 PM   #27
Spark Plug's Avatar
v6's sound good at idle. i just don't think i've heard one that sounds good at WOT, although kyles is prob the best soundin i've heard. it's the least import sounding
Spark Plug Racing- "If it Breaks It Was Meant To Be Upgraded
2003 Dodge Ram HEMI
2008 Suzuki Kingquad 750 4x4
Spark Plug is offline   Reply With Quote
Old 08-24-2008, 11:01 PM   #28
Send a message via MSN to briandegans Send a message via Yahoo to briandegans
Just got Steeda's V-6 Cat-Back Stainless Steel Dual tips with Borla's dual exhaust on my Pony - I am very impressed with the sound. It sounds like the Cobra down the street yet it's only a 232.
briandegans is offline   Reply With Quote
Old 08-25-2008, 02:39 PM   #29
Kyle... one last question. Do you have 3'' or 3.5'' tips?
Old 08-25-2008, 05:35 PM   #30
Send a message via AIM to VCS_SSSTANG
And my exhaust!
VCS_SSSTANG is offline   Reply With Quote
Old 08-25-2008, 06:27 PM   #31
And that is?
Old 08-25-2008, 06:37 PM   #32
And that is?
/flow original 40s/
/mac long tubes/
/mac prochamber/
Old 08-25-2008, 09:12 PM   #33
3.5" SS magnaflow tips
Old 08-25-2008, 11:39 PM   #34
1234's Avatar
VCS_SSSTANG your exhaust dont sound to bad either.
Old 08-26-2008, 01:02 AM   #35
DarkShadow's Avatar
Send a message via AIM to DarkShadow
My exhaust...but to get this sound, it will take a little more modification than you might want to do...
vid 1
Vid 2
DarkShadow is offline   Reply With Quote
need help deciding which is better Skyes97Stang Pre-2005 V6 Mustang 11 11-28-2008 02:34 PM
2006 Exaust tkdubb Pre-2005 V6 Mustang 7 05-14-2008 04:00 AM
Deciding to mod my V6..... SuperItalian Pre-2005 V6 Mustang 7 06-12-2007 10:42 AM
Need a Little Help Deciding bluemustang Mustang Audio & Video 15 02-15-2007 05:40 PM
94-96 gt exaust on a 99+? blk2kconvstang Pre-2005 V6 Mustang 1 03-21-2004 06:45 PM
07:57 AM
