best cam and heads for roots s/c - Mustang Evolution
Old 01-15-2004, 03:00 AM   #1
tire's Avatar
Send a message via AIM to tire
RGR will be doing mine in due time, but i'd like to bring this up for debate and to school me as well. hopefully someone BESIDES mr. greene will also add something to this.
so, what cam and heads would be best suited... will the fact that full boost will be had at ~1.5k rpms make a difference in the cam/head specs? centrfugals take a little bit to build up, say ~3krpms.
care to compare/contrast and offer solid numbers of best i/e cfm's for the heads and cam specs? assume 11psi for both.
it would seem to me that if anything more exhaust would need to be flowed with the roots maybe because of the full rpm range? what can be done to combat the roots' ineffeciency?
-austin
tire is offline   Reply With Quote
Old 01-15-2004, 05:48 AM   #2
Danger Dude's Avatar
The best heads would be the ones that flow the best especially if you are going supercharger. With a N/A motor you can have have so much flow it kills HP. But with a S/C I dont know if it is actually possible to have to much flow considering you need a BOV with a SC for unused air. As for cams there are a few variables to decide if you want a stock idle or a lopy idle. RGR and others have come up with some nice cam alternatives. Do you want an all out take no prisioner lopy idle monster or do you want a Nice very fast but somewhat docile Idle ???
Old 01-15-2004, 08:09 AM   #3
Monkey's Avatar
214 cam.. have some balls
Old 01-15-2004, 08:13 AM   #4
My 216/225 has balls but it is for a Single Port
Old 01-15-2004, 08:19 AM   #5
Monkey's Avatar
for some reason, i was thinking 216 is too big for split ports. i cant remember exactly though. im sure rgr will clarify when he gets in here
Old 01-15-2004, 11:09 AM   #6
tire's Avatar
balls to the walls, of course, dangerdude. just ask brandon, i bez mad hardcore y0.
Old 01-15-2004, 02:17 PM   #7
RGR
Send a message via AIM to RGR
216 is big for a split port 3.8 but boost would help it lots.
It seems the duration likes an RPM band the intakes do
not work well with. This is mostly NA 3.8 though.
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 01-15-2004, 02:49 PM   #8
Monkey's Avatar
so 216 would be okay for austin? what about 214?
Old 01-15-2004, 04:09 PM   #9
Hey Robert where you been!!! Hope the holidays were good to you !!!
Old 02-07-2004, 08:43 AM   #10
RGR
I'm back!!!
214 or 216 cam is so close that it's almost the same...
I really need all the combo info to make a good call,
and no need to do that until the cam is beibng ordered.
Old 02-07-2004, 09:59 AM   #11
tire's Avatar
RGR, we just got a customer of sorts that should give us the capital we need to get things rolling. at first we'll test it on a stock motor but once the dynotune is done i will be putting a cam in. how best can i contact you for advice on how to get the most from a STOCK motored splitport v6 with only a custom intake and roots m90? 80mm or 90 maf? advice is most needed and tips most appreciated.
heads and cam jjbg86 1979-1995 Mustang GT 10 03-04-2007 12:01 PM
FS: BV Heads, 173's,Cam, and Stock Heads petrey10 Mustang Parts for Sale and Wanted 4 06-26-2006 11:15 PM
I GOT MY HEADS/CAM!! Kiljosh Pictures and Videos 8 11-24-2005 09:04 PM
Heads and Cam!!!! Kiljosh Pre-2005 V6 Mustang 30 05-16-2005 10:34 PM
new cam and heads bigpomps Pre-2005 V6 Mustang 58 04-08-2005 10:54 AM
04:25 AM
