36k miles any thing i am over looking to do? - Mustang Evolution
Old 01-16-2004, 06:41 PM   #1
well i just hit 36k and besides a oil change, fuel filter, and tire rotation with alignment what else do i need to do? any little things, i changed the tranny fluid a wihle back so thats still good.
Old 01-16-2004, 07:47 PM   #2
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
30,000 miles
-Change Oil and replace Oil filter.
-Adjust clutch by lifting up on pedal
-Replace Air filter
-Inspect cooling system, hoses, clamps. Check coolant strength, change if needed.
-Change automatic Transmission Fluid.
-Inspect Exhaust heat shields.
35,000 miles
-Rotate Tires and adjust air pressure
40,000 miles
Rellik is offline   Reply With Quote
Old 01-16-2004, 07:50 PM   #3
id go ahead and check everything, brake fluid, rear diff, tranny, hoses, give your sparkplugs a looksie see how their aging look for anything abnormal.
check the pcv valve see if theres to much carbon ect. little silly things.
I usually pull and check everything when i do oilchanges (if i have the time)
Old 01-17-2004, 01:37 PM   #4
yea i will check the fluids, i rememberd i need to get my coolant changed any help in this area, how do you fluish it to get It all out of the system so i dont have old and new in there?
Old 01-17-2004, 05:10 PM   #5
slvr2000stang's Avatar
Have you changed your fuel filter yet?
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 01-17-2004, 05:41 PM   #6
yea i changed it 10k ago.
Old 01-17-2004, 08:06 PM   #7
Danger Dude's Avatar
what about your rear end lube I change mine every 18 months and add friction modifier
Old 01-18-2004, 01:24 PM   #8
changed it like 3k ago....
I got 5W 30 Mobile 1 oil (dont make 5W 20... and 0W 20 was not there and probably not good to use)
got premix coolant to use 2 gallons ok?
gonna get fuel filter thats about all i know to do.
Not sure what to think of this thing Scorpion1 Pictures and Videos 17 02-21-2009 06:13 AM
Thing to know about the 3.8 Herbstang Pre-2005 V6 Mustang 2 03-15-2007 07:06 PM
One Thing That Really Gets To Me bluemustang The Bar 10 11-03-2003 06:33 PM
02:13 AM
