Power Sterring - Mustang Evolution
Old 01-17-2004, 10:26 PM   #1
Send a message via AIM to 98MustangV6
Power Sterring
ya i dont know what is wrong but when i turn my wheel to the right or left it makes a weird noise like my power sterring pump is going out or somthing. any one help.
All stock but about to change!!!
98MustangV6 is offline   Reply With Quote
Old 01-17-2004, 11:09 PM   #2
Ponycarman's Avatar
Low on fluid usually makes a groaning noise.
Sometimes, if you turn the wheel as far as it'll go in one direction the pump will make noises, that is normal if it only happens when you hit the stops.
If it's noisy just turning it a bit then check the fluid.
Steve
1996 Mustang
1965 Barracuda
Originally Posted by slvr2000stang
Holy crap he's right.
Ponycarman is offline   Reply With Quote
Old 01-24-2004, 02:45 PM   #3
Mine too
Does the normal sound seem like a squealing noise? Could that be a loose belt??
I think the fluid level is fine.
njstang97 is offline   Reply With Quote
Old 01-24-2004, 02:50 PM   #4
Rick0636's Avatar
on cars with serpentine belts we usually don't have a problem with loose belts much, unless its the wrong size or really worn out bad. That is because you have a tensioner there to keep it snug.
Old 01-30-2004, 07:54 AM   #5
Danger Dude's Avatar
well the first thing I would check is the fluid, mine seemed to be louder than normal and the steering fluid was nasty and milky. There was a considerable amount of entrained water in the steering fluid. once I changed it the noise level decreased by 50%. Actually the Ford power steering unit is a fairly noisey
no power!! sledgehammer 1979-1995 Mustang GT 2 03-16-2008 09:56 PM
It takes power to make power sporter 2005-2010 Mustang GT 3 05-13-2007 06:40 PM
better for power? tedness Pre-2005 V6 Mustang 12 01-07-2005 08:29 PM
Power or Looks Black95GT The Bar 17 08-18-2003 12:10 PM
01:58 PM
