what could it be?? - Mustang Evolution
Old 01-18-2004, 10:41 PM   #1
Send a message via AIM to v6white98
what could it be??
Every time i hit a bump (not necessarly a big bump) i hear a
a lot of rattling going on in the back. When i stomp on
the gas, my back end sways back and forth. Well my friends have
told me that my suspension might be messed up.
oh and when i go around a turn, around 25mph (nice weather out too),
i fishtail.
Could it be the suspension???
If so, what should i get. Any ideas??
-thx
-Matt
v6white98 is offline   Reply With Quote
Old 01-19-2004, 05:46 AM   #2
that's definetley the suspsension, what on the suspension though? im not sure, wait a couple hours and im sure someone will post a more helpful reply.
2000 Chevrolet Tahoe LS
5.3L VORTEC (not V-TEC) V8
4-Speed Automatic 4x4
Garaged:
1990 Ford Mustang GT
5.0L V8
4-Speed Automatic Overdrive
ItWouldAppearSo is offline   Reply With Quote
Old 01-19-2004, 11:04 AM   #3
Rick0636's Avatar
It is really hard for me to say from that discription. I think you need to take it in and get a good mechanic to look at it though. Doesn't sound safe to drive much that way. Alternatively you could raise it on jack stands and check to see if you can find anything loose or bolts missing etc. But unless you are pretty good at fixing things I would say take it to a pro.
Old 01-19-2004, 01:36 PM   #4
Zim
You want to **** me?
Zim's Avatar
what year is your car? sway bar could be messed up or loose shocks/struts... that couild be a lot of different possiblities, id suggest a mechanic as well.
I like toys
Old 01-19-2004, 11:38 PM   #5
Dom
Dom's Avatar
Send a message via AIM to Dom
i fishtail.
That's a good thing.
Old 01-19-2004, 11:51 PM   #6
Monkey's Avatar
imma go with loose upper control arm bolts. get that fixed immediatly. it ruins your alignment of the rear end, if it goes too far out, it can stretch the brake lines, and it also has negative effects on the tire wear.
Old 01-20-2004, 12:35 AM   #7
I'm going to go with bent panhard bar.
Laser02 is offline   Reply With Quote
Old 01-20-2004, 05:26 AM   #8
funny because we dont have one
I think he means swaybar.
1998 Subaru Legacy L Sedan
New Hottness
1999 V6 5-speed
14.6 @ 95 w/ 2.22 60'
Wrecked
stangin99 is offline   Reply With Quote
Old 01-20-2004, 08:18 AM   #9
Rick0636's Avatar
Yeah, have to spend about 300 or 400 to get one, then bend it, huh??
Old 01-20-2004, 08:25 AM   #10
I just wanted to see how many people would catch that.
Old 01-24-2004, 05:01 PM   #11
Ponycarman's Avatar
I had a old Dodge cop car, well I still have it, that had a rattle in the rear suspension. Took me forever to find it. How I ended up finding it was to put it up on jackstands, under the axle, and smack various components with a rubber mallet. Ended up being a leaf spring pack clamp, not applicable here.
A good visual inspect is where I would start. If nothing is obvious get out the rubber mallet.
Steve
Oh yeah, is there a market for a panhard bar that costs in the $150.00 range? If so PM me I might start making them is the demand is justified.
1996 Mustang
1965 Barracuda
Originally Posted by slvr2000stang
Holy crap he's right.
Ponycarman is offline   Reply With Quote
Old 01-24-2004, 05:12 PM   #12
Rick0636's Avatar
Steve, I wouldn't doubt it if the quality were there and it could handle a GT or a V6, the ones on the market are a bit on the pricey side, and it is a popular mod! I won't be needing one since I am going to 03 Cobra IRS in another week or so.
Old 01-27-2004, 05:40 PM   #13
I would get a drive on lift and tq all the upper and lower control arm bolts down correctly and make sure every thign loosk good all bushings are good and what not, and then check the shocks mounts and make sure they are bolted on correctly chances are its that, cuz really thats all there is to the rear end.
03:23 AM
