Problem with the cooling fan coming on... - Mustang Evolution
Old 08-24-2008, 07:06 PM   #1
Kiljosh's Avatar
Hey everyone having a little trouble here. My cooling fan won't come on when it comes up to temperature...
I checked the fan it will turn on if you connect a battery to it. The fuses for the CCRM under the dash and the EEC/CCRM in the High current box are both fine. So does this basically eliminate all other possibilities besides a faulty CCRM?
Whats a new CCRM cost me from ford you think....
Old 08-24-2008, 10:35 PM   #2
Scut95's Avatar
Re: Problem with the cooling fan coming on...
The CCRM should be clicking a relay for the fan. Check to see if the relay is still ok first if yo were just giving straight power to the fan. If not then it's possible that the CCRM and PCM aren't communicating. I don't know the cost of a new CCRM but im sure it isn't cheap. I'm guessing between $300-500 for the part, and im sure you can't get it anywhere but a Ford dealer or a junk yard.
95 GT- Sold
09 Hyundai Elantra Touring-new ride.
Looking for the next project car now
Old 08-25-2008, 07:20 PM   #3
Kiljosh's Avatar
Where is the relay for it? Do you know how I would go about checking it?
Old 08-26-2008, 12:45 PM   #4
Scut95's Avatar
what year is your car? ill see if i can find the location of the relay. This website tells you how to test the relay. Cars have a 4 post relay numbers should be 30,85,86,87. Relays - Operation & Testing
95 GT- Sold
Old 08-26-2008, 01:53 PM   #5
Kiljosh's Avatar
Car is a 1997.
I dont have a voltmeter is there a backwoods way I can test then? Maybe give a small charge to it listen for a click I dunno.
Old 08-26-2008, 04:52 PM   #6
Scut95's Avatar
Car is a 1997.
Yup that should work. Just give it some power and see if it clicks. As for location of the relay, check in the main fuse rely (power distribution center) in the engine compartment for the relay. If the relay is ok, i forgot that the cooling fan also works in conjunction with the ECT (engine coolant temp sensor) as well. Your car is OBD II which should pick up on that but never rule it out. Also, the fan is a 2 speed set up on these cars. Does the high speed fan come on when the AC is on? Post back up and let us know how its going
95 GT- Sold
Need help with cooling system Dman Pre-2005 V6 Mustang 5 06-16-2007 10:35 PM
cooling fan upgrade madmax680 1979-1995 Mustang GT 8 06-09-2006 12:34 PM
cooling 9899musl 1996-2004 Mustang GT 0 03-14-2006 05:24 PM
Cooling issues lightning 1996-2004 Mustang GT 5 10-12-2005 10:12 AM
My Cooling System 04MonteSS The Bar 12 07-30-2005 03:50 PM
10:05 AM
