Tranny Problem.... - Mustang Evolution
Old 01-19-2004, 07:38 AM   #1
Send a message via AIM to v6mustangguy Send a message via Yahoo to v6mustangguy
Tranny Problem....
I have a 98 V6 5-Speed....and I was told that my synchronizers are rattling, and they are making noise....they said its nothing to worry about. Is that true, or is there anyway I can get them to stop making like a metal clinging noise. Thanks!
v6mustangguy is offline   Reply With Quote
Old 01-19-2004, 01:28 PM   #2
somebody????anybody????
Old 01-19-2004, 02:47 PM   #3
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
When does it do it? only in certain gears? all the time? Accelerating? Coasting, Idleing? ect...
Fill us in with all the info and specs.
Rellik is offline   Reply With Quote
Old 01-19-2004, 03:14 PM   #4
it does it all the time, and it doesn't when I have the cluth pressed in...but idle, speeding up...coasting with cluth not pressed down, and when slowing down. But once I put pressure on the cluth it stops
Old 01-19-2004, 03:16 PM   #5
is it more of a whine?
sounds like a Throw out bearing issue
Old 01-19-2004, 04:11 PM   #6
no its not a whine...its like a loose piece of metal, and like vibrations are making it rattle on another piece of metal. Like at first I though it was the heat sheild on my cats rattling...but its not that
Old 01-19-2004, 05:07 PM   #7
funky, sounds like its time to rebuild.
Old 01-19-2004, 06:11 PM   #8
I have not the slightest clue on how to do that. About how much is that going to run me? or would it be cheaper to get a new tranny?
Old 01-27-2004, 05:37 PM   #9
if it rattles when the clutch is out and when you push it in the rattle goes away its a throw out bearing, i have been though 4 lol they are super cheap. does the tranny shift smootha nd good? no grinding? if the tranny is good then i would simply replace the clutch, pressure plate, resurface the flywheel REALLY GOOD or better yet buy a new one they are dirt cheap why risk issues, then get a new fork arm, pilot bearing, throw out bearing, bearing retainer, and clutch cable and quadrent its all pretty easy to put in since you have to take all but the pilot bearing off pretty much to swap in a clutch, expect 200 for labor plus the parts price.... www.gefracing.com is really good for oem stuff you can go with what ever brand you wish adn get a PROFESSIONAL to do it not a shade tree mechanic.... make sure you get a new cable and steeda or upr multihook quadrent (double hook = steeda 3 hook = ups) and a firewall adjuster to correctly take up the slack in the cable to prevent the noise from comming back later on down the road. i know it seems over kill but trust m you dont want to pay 400 bucks and it have th same noise before you did the job....
Old 01-29-2004, 11:18 PM   #10
I had it looked at, and when they replaced the clutch when i bought the car. they installed defective throw out bearing and pressure plate. So they are going to replace both of those and the clutch for free because of that. So that works good
Old 01-30-2004, 07:07 AM   #11
Danger Dude's Avatar
Make sure they also check the shift fork that the throwout bearing mounts on. If the fork arms are bent or out of alignment that can cause premature bearing wear and noise
Old 01-31-2004, 03:49 PM   #12
you dotn bend shift forks, you break them, its a myth
Old 01-31-2004, 03:55 PM   #13
I have had bent shift fork's Pretty real myth to me. They can get hot and fatigue!!!
Old 01-31-2004, 04:39 PM   #14
maybe its not the same part i am thinking of, but something like that.
Old 01-31-2004, 04:52 PM   #15
I am talking about the fork the throw-out bearing rides on. Those fingers can heat up and deform causing misalignment. the whole thing does not deform just the carrier area due to head and pressure
Old 01-31-2004, 05:08 PM   #16
01mineralgrey6's Avatar
That happend on my Dads '97 GT. The fork was bent, then the pressure plate wore out funny, or something like that.
-Tony
'99 cobra 'vert
Old 01-31-2004, 06:11 PM   #17
im talking about the forks in the tranny no thte fork arm, yes the fork arm can warp and screw up and what not.
tranny problem ? 1 dark demon 2005-2010 Mustang GT 21 10-31-2008 02:03 PM
Tranny Problem? i think... DMAC Pre-2005 V6 Mustang 2 05-16-2007 03:08 PM
Tranny/Shifter problem... Fast93Coupe 1979-1995 Mustang GT 6 04-22-2006 03:26 PM
Shifter clutch or tranny problem??? PA6shooter Pre-2005 V6 Mustang 10 04-28-2005 08:15 AM
tranny problem? 232SCstang Pre-2005 V6 Mustang 3 03-15-2004 01:15 PM
10:24 PM
