Shuddering when starting from dead stop - Mustang Evolution
Old 07-17-2003, 03:28 PM   #1
Yo Testicleez... did you ever find out what was up with your clutch? Mines gettin worse, and im gettin ready to take it somewhere to get looked at.
Joshness is offline   Reply With Quote
Old 07-20-2003, 11:54 PM   #2
Originally Posted by Danger Dude
That really sounds like the pressure plate not evenly engaging
Corey
Sorry I didn't update you guys on this. About a month ago I had the shop tear it down again. They said everything was fine. No uneven wear, no runout on the flywheel, nothin.
Bad news, it still did it. Joshness is not the only one I've talked to that's had this problem, funny thing is is that its only been with the centerforce stage 1 kit.
When I installed the pedal height adjuster from MM I had to tighten down the adjustable cable (non firewall adjuster) to take up the slack and have proper disengagement/engagement, this seemed to help, but every once in a while it will still shudder. I've just grown to accept, its just annoying because it causes my cai to hit my strut tower.
I think the lesson learned here is that the c/f stage 1 kit sucks. I don't think I'll be buying from them again.
2000 Black V6, 5spd, 1.8 Roller Rockers, Mac CAI, Mac Longtube Headers, Mac Off-road H-pipe, Flowmaster Force II Catback, Ford T-lok (on 2nd one), 3.73 gears, LUK Clutch, MM pedal height adjuster, Ford Aluminum D/S, Eibach Pro Kit Springs, Koni Yellows, HPM Megabite Jr LCA's, Cross-drilled/slotted rotors (11" F, 10.5" R), S/S brake lines, Eibach front/rear sway bars (1.25" F, 1" R), Pro 5.0 Shifter with Steeda Tri-Ax handle, ROH Snyper rims (17x8 F, 17x9 R), Kumho Ecsta 712's (245/45/17 F, 275/40/17 R), GT fog lights, Smoked/Cleared Headlights.
Testicleez is offline   Reply With Quote
Old 07-21-2003, 03:12 PM   #3
I was very close to taking my car in this weekend and getting a rental car to have them do a tear down to look at mine as well. Sounds like its a good thing that I didnt. How many others do you know of that are having the problem?
Old 07-27-2003, 04:37 PM   #4
Send a message via Yahoo to x77911
i have my OEM (ca. 1998) clutch and i notice the same thing, but only when reversing from a dead stop up my inclined driveway at around 1000rpm. if i disengage the clutch and go up above 1500 rpm the shuddering stops. i have 77k miles on the vehicle.
x77911 is offline   Reply With Quote
Old 07-31-2003, 04:29 PM   #5
I broke down and brought my car in, because the shaking was getting so bad I thought the tranny was gonna fall out.
Its in the shop right now, and they told me that the Pressure Plate on the Centerforce was bascially dissolved. The wire ring that has the centrifigual weights on it (centerforce only) was all screwed, and the 1/2 weights came off. Hence the shuddering. THey also said the plastic CLutch Quadrant/Adjuster was broken, so the ford "Auto adjusting Clutch" wasnt working anymore either.
The good news, the clutch was still under the 90 warranty - so free parts. The Quadrant is also being replaced with a Billit FRPP piece, so that will be fixed too.
The bad news, labor, plus the extra part needed will still cost me about a toal of 450 bucks.
Stay away from Centerforce, and everyone should replace thier Stock PLASTIC Quadrant with an alluminum one (~$100 for the kit).
"Ford, where quality is job one." <-- MY ***!!
Old 07-31-2003, 05:44 PM   #6
you need to buy a quadrent adn adjuster and put just enough tention on it so that it does not slip when driving. just a tad bit of pressure on the cable all the time. i would buy a new cable and a quadrent with an adjuster and try that out. My friends nissan with a spec cltuch does the same thing its terrible....i figured it was cuz he didnt have enough tq and the pressure plate clamped down on it hard and he didnt have the car moving fast enough to over come this issue.
to shake there would have to be something wrong with the pressure plate, flywheel, or the springs on the clutch disk, which are there for that exact reason to aborb the tq energy to keep the car from shaking....
also the input shaft could be moving a bit or something odd like that....
i would contact centerforce and get a new pressure plate from then adn disk....if you can that is.
Old 07-31-2003, 06:24 PM   #7
Uhh, did you even read my last post.
Its basically trhe same thing you just explained. The pressure plate was screwed up, and the quadrant broke. Both of them are geting repaired/replaced.
Old 08-01-2003, 02:50 PM   #8
CLUTCH = RIP
ok, about 5 minutes after i pulled out of my friends house my clutch starts shuddering while going into 2nd. So i pull off and try to adjust it. Nothing. Then, i start out of 1st and its squeeling and clanking and popping like a mofo. Same with 2nd gear. Then, i shift to third and its still hard to press, but it doesnt ake noise. So i took it to the shop. Anyone have a prob like this? BTW, there was white smoke under the hood when i stopped, and it...
"SMEELEED LIKE BUURNING!!!!"
http://www.mustangmods.com/data/1581/sig3.jpg
Check out my car on cardomain!
CAI (99+), 17" 01' GT rims, Hankook hrII tires, interior switch pony, dressed up engine (blue), other numerous appearance mods
Sil\/erSpeed is offline   Reply With Quote
Old 08-01-2003, 04:01 PM   #9
Sil/erSpeed,
Aftermerket or stock clutch? How many miles on the car?
If you have the original stock clutch, it might just be going out. If you get it replaced, DONT BUY CENTERFORCE - centerforce is a good comapny, dont get me wrong, but they cant seem to make V6 Stang clutches worth a damn
Old 08-10-2003, 09:31 PM   #10
From dead stop/even in park? 306BIGDADDY 1979-1995 Mustang GT 13 08-20-2010 09:28 AM
Video: Jet vs. 996 TT vs. R1 bike from dead stop PureVenom 1996-2004 Mustang GT 13 09-20-2005 07:39 AM
Ah!ah! Stop! Stop It!!! chips The Bar 21 09-24-2004 06:09 PM
wheel hop so bad it feels like bogging/shuddering tire The Bar 3 07-18-2003 08:54 PM
11:20 AM
