SON OF A..... - Mustang Evolution
Old 01-23-2004, 08:50 PM   #1
Tbird232ci's Avatar
SON OF A.....
Well...a buddy of mine has a 91 Cougar, showning a few sympoms of headgasket failure, we're going to further investigate tomorrow, but so far
-ran a bit funny
-engine didnt warm up
-blowing smoke (didnt smell like coolant, but still alot of smoke)
-making a gurgling noise under the hood
-coolant system was hardcore pressurized
no coolant/oil mixing that i can tell yet
any other things we should look at? coolant will make a sparkplug look pretty much spotless wont it?
Old 01-23-2004, 09:13 PM   #2
Ponycarman's Avatar
Color of smoke?
White - coolant
Black - too rich
Grey - oil
Pink - find a new friend
Yes, coolant will pretty much clean the plug's porceling tip spotlessly. On cold and humid days it is normal for the tail pipe to emit white smoke (it's really steam) till it's fully warmed up.
Steve
1996 Mustang
1965 Barracuda
Originally Posted by slvr2000stang
Holy crap he's right.
Ponycarman is offline   Reply With Quote
Old 01-24-2004, 11:00 AM   #3
Tbird232ci's Avatar
smoke was white
well, its definatly a head gasket, since we have snow on the ground, you can actually see the snow turning green from the coolant, i put my hand under the tailpipe and i had actual coolant on my hand from it
we're planning on doing it ourselves...anyone have a rough idea or the cost of doing both headgaskets, new bolts and the rest of the gaskets?
Old 01-24-2004, 11:49 AM   #4
Rick0636's Avatar
No, not really, but at minimum you absolutely have to have the heads resurfaced or you will be wasting your time, and you might as well get a valve job while you are at it.
Old 01-24-2004, 03:30 PM   #5
Tbird232ci's Avatar
thats the plan
whats strange, the car never overheated, never had spark knock, nothing of the sort, it just said "F U" and started dumping coolant out the exhaust
we had it running for like, 2 minuets, and coolant actually puddled out of the exhaust
Old 01-24-2004, 03:53 PM   #6
Rick0636's Avatar
Who said anything was strange? I think its just sort of what happens with 3.8 headgaskets sometimes, poor design or something, its really more of a head design problem I hear than a gasket design problem.
Old 01-24-2004, 04:28 PM   #7
Tbird232ci's Avatar
i meant that what i was saying was strange, DUH!
its a few things, aluminum head/iron block, not so great gaskets, and a few other things are usually the cause, but it just popped outa nowhere, no temp problems or anything
Old 01-24-2004, 04:58 PM   #8
Ponycarman's Avatar
You may want to see if Ford has a TSB on this problem with a resolution to it, such as better headgaskets, revised headbolt torque value/tightening pattern, etc.
My wife had a Neon that had similar issues. The resolution ended up being a redesigned headgasket, from composite to multilayer steel, new torque values and proper prep. I did the job myself and it took me an afternoon, being real anal about the job.
I'd expect it to take longer for you. The key is proper prep. Clean all the old gasket off the surfaces or it will leak again. Resurfacing the head is a good idea, but you can measure the deck and check for warp. I advise egtting a repair manual, it'll tell you how to measure it.
Steve
1996 Mustang
1965 Barracuda
Old 01-24-2004, 07:27 PM   #9
Tbird232ci's Avatar
with the neons, you could also get away with just retorquing the head if the gasket wasnt blown, similar problem with the 3.8L, aluminum head on an iron block, and after a certain amount of miles, the head bolts need to be retourqued
i dont see head warpage being a problem, seeing as it never overheated, but its still getting checked, and heads most likely getting milled a bit
Ford had a recall a few years back, kind of an "underground recall", and they used graphite headgaskets instead of what they were using, but either way, from the research ive done, felpro is probably the best way to go, along with ARP head bolts
Old 01-24-2004, 08:55 PM   #10
Dom
Dom's Avatar
Send a message via AIM to Dom
My friend's truck has a blown headgasket. His dad refuses to believe it. So he put a new water pump on it.
Showing all the signs. Overheats, uses coolant, water on plugs, exhaust blowing up through radiator. :no:
Old 01-25-2004, 10:06 AM   #11
OEM Ford 99+ headgaskets are just as good if not better than the fel-pros.
1998 Subaru Legacy L Sedan
New Hottness
1999 V6 5-speed
14.6 @ 95 w/ 2.22 60'
Wrecked
stangin99 is offline   Reply With Quote
Old 01-25-2004, 11:16 AM   #12
Danger Dude's Avatar
Ok The problem with the heads leading up to 95 was the the coolant holes to close to the cylinders
do work....son. D00DIEBR0WN New Member Introductions & Greetings 6 10-12-2009 07:26 AM
son of a bit-- Kyle Pre-2005 V6 Mustang 5 09-26-2007 07:16 PM
Is your son a Computer hacker? Brent The Bar 45 07-01-2007 02:27 PM
Kyle get owned again, son of a......... Kyle The Bar 15 06-19-2005 10:20 AM
my son... i'm so proud dark The Bar 7 08-10-2003 09:59 AM
08:19 PM
