Error Code Overload - Mustang Evolution
Old 08-27-2008, 08:16 PM   #1
IMP
Error Code Overload
I have a 1995 Mustang with a V6 and am experiencing erratic idling. Half the time when stopped in drive I have to use two feet because it will stall. Check Engine light is ON and the following codes re-appeared after clearing:
P0113 IAT Sensor 1 Circuit High Output
P0102 MAF or VAF A Circuit Low Input
P0174 System Too Lean (Bank 2)
A year ago I replaced the IAC Valve and it worked great so recently I pulled it and cleaned it but it was already clean and this had no effect. The exhaust smells as if the engine is idling under fuel-rich conditions. Given the three codes, can anyone recommend a starting point or shed light as to what may be going on?
IMP is offline   Reply With Quote
Old 08-27-2008, 08:56 PM   #2
Scorpion1's Avatar
Re: Error Code Overload
Sounds like your MAF is dirty or shot if the system thinks its running lean, but smells rich.
WiCK3D_SiX
Scorpion1 is offline   Reply With Quote
Old 08-27-2008, 11:02 PM   #3
1234's Avatar
Cleaning your maf is a good place to start.
Error Code P0411 Shahrum Pre-2005 V6 Mustang 33 06-29-2016 06:59 AM
The dreaded p0411 Error Code MaxonMustang Pre-2005 V6 Mustang 7 04-28-2009 07:16 PM
EGR Error Code bigpomps Pre-2005 V6 Mustang 14 04-18-2006 05:26 PM
Just an error message I got Kiljosh ME Site Help & Announcements 4 07-03-2005 12:20 AM
» Members Mustangs
Red
Red89
Stang
93stang306
Add your Mustang
07:03 PM
