check engine soon light finally off - Mustang Evolution
Old 01-24-2004, 06:18 AM   #1
i took my car to autozone on thursday to get my code read so that i can see what is causing that light to go off. the guy read the code and said that i had a leak in my fuel system and he went to the gas cap, took it off and put it back on, went back to the car cleared the code and it hasn't come back i would have never imagined that something so simple would cause the light to go off. now when i put gas and put the cap back on i give it an extra little snug to make sure it closes right.
2000 5spd black/ cai w/ k&n, dual exhuast w/ H-pipe
stangracer is offline   Reply With Quote
Old 01-24-2004, 03:01 PM   #2
It'll do it every time. Be glad you didn't carry it up to ford, they would have charged you the 75 dollar fee just to tell you to tighten your gas cap and said something else was wrong. Good call on going to auto zone lol.
Old 01-25-2004, 12:50 AM   #3
Ponycarman's Avatar
You gotta be careful with the AZ clowns.
I had a check engine light two weeks ago. Had Bozo run the codes, the scanner said I had two codes but Bozo would only show me one, said he couldn't call up the second till I fixed the first one, then proceeded to tell me it was the gas cap.
I took the scanner from him, called up the second code and wrote both down. Went home and the codes were IAC related. So I cleaned my IAC, cleared my codes and haven't had a problem since.
Steve
1996 Mustang
1965 Barracuda
Originally Posted by slvr2000stang
Holy crap he's right.
Ponycarman is offline   Reply With Quote
Old 02-03-2004, 06:55 PM   #4
Send a message via AIM to !*!STANG!*!
My check engin light is also on, and has been sence i got the car around mid June of 03'. I took it to AZ and the clown read the codes. There were 4 codes that came up, Three of them said "See Dealer" and one read Bad Oxygen Sensor... I asked him how much it would cost to just replace the OS and he recomended me taking it to the dealer and getting the other codes read because thos three could be making the one bad OS sensor problem... Any Ideas? or should i take it to Ford???
White 95 5 Speed V6
Mods: Audiovox Head(temporary)
Future Mods: 1 JL 10W3v2 in a ported box, JVC Arsenal KD-SX9350, 4 Infinity Kappa 572.5cf, Custom True Dual Exhuast and gutted cat, SSX Sheetmetal Upper Intake Manifold, Paint, Eibach Pro Kit and Eibach Pro Damper Kit plus more im only 15 so i have pleanty of time :)
!*!STANG!*! is offline   Reply With Quote
Old 02-04-2004, 10:41 AM   #5
Ponycarman's Avatar
woulda been nice if you had the code numbers, The AZ scanners will cough up the code. Then you gotta get the book and read what the codes say. If we knew the codes we could probably answer the question.
Steve
1996 Mustang
1965 Barracuda
check engine
check engine light on! 1999Stang Pre-2005 V6 Mustang 2 08-09-2008 12:04 PM
Check Engine Light? braumab 2005-2010 Mustang GT 11 06-24-2008 02:58 PM
Need Help with Check Engine light dch61407 1996-2004 Mustang GT 2 01-30-2008 07:01 PM
check engine light avery_y Pre-2005 V6 Mustang 9 01-13-2007 06:16 PM
check engine light mustangruss Pre-2005 V6 Mustang 1 04-02-2006 09:49 PM
01:03 PM
