New Cam?? - Mustang Evolution
Old 01-25-2004, 10:49 AM   #1
New Cam??
Would a cam and valve train upgrades be beneficial after the basic bolt ons (CAI, exhaust, UDP, spacers) and ported intake? Also, how beneficial would a cam swap be without vavle train upgrades?
mesagsxbkr is offline   Reply With Quote
Old 01-25-2004, 10:56 AM   #2
oaktonarcher's Avatar
Send a message via AIM to oaktonarcher
Well this is what i kno. yes bolt ons help a cam a good bit (help it breath). RGR sells a 207/215 cam that from what I hear is pretty nice. porting your heads really helps you cam breath and can add as much as 20 rwhp with a cam. and what year mustang do you have?94-98 or 99-04.
Delta Sigma Phi
building better men since 1899
You still have a quote in your sig from a guy that hasn't signed in in almost 2 years
www.DeltaArmsCo.com
oaktonarcher is offline   Reply With Quote
Old 01-25-2004, 10:59 AM   #3
99-04, an 01, thanks for the quick reply
Old 01-25-2004, 11:12 AM   #4
o 01 you should get the 207/215 B/c your car is split port and that way you will def. pass emissions testing. and you do need to change your springs when you do this just so u kno. u prob . knew but i figured i would tell you
Delta Sigma Phi
www.DeltaArmsCo.com
Old 01-27-2004, 09:01 PM   #5
If you're doing the install yourself a cam swap is a great bang/buck mod.
It's not quite as great if you have to pay someone to install it for you.
Drop me a line, you may not even need to pick up new valve springs
depending on what you have on there right now.
-Mik
Redlined Performance Mustangs
Cylinder Head / Intake Porting, Camshafts, Pistons, Cold Airs/Pulleys
www.rpm-mustangs.com
http://rpm-mustangs.com/pictures/KEcrank.jpg
mikael is offline   Reply With Quote
Old 02-07-2004, 08:38 AM   #6
RGR
Send a message via AIM to RGR
Actually, I send out a cam form and custom grind each cam to
the user's needs. 207/215 is an SC cam for most people w/SPI
and it can handle lots of boost. I have cheap(er) upgrade springs
for many cams or awesome hi-dollar springs for all years. And it is
true, certain years can use stock springs with certain grinds, and stock
pushrods with many SPI grinds.
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Which Cam? b's stang 2005-2010 Mustang GT 2 07-18-2010 10:25 PM
3.8 V6 Comp Cam Performance Cam nmaraijko Mustang Parts for Sale and Wanted 0 11-15-2006 07:11 AM
Cam Cores needed for RDMotorsport cam GP RGR Mustang Parts for Sale and Wanted 3 03-05-2005 05:53 AM
cam and rr? cjd10 Pre-2005 V6 Mustang 16 02-08-2005 04:12 PM
11:43 PM
