My car's idle is all screwed up. - Mustang Evolution
Old 01-28-2004, 03:13 PM   #1
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
Sometimes my car will randomly decide that it needs to idle at anywhere from 2500-3800 RPM. If you blip the throttle all the way open, the rpm's spike, drop to normal then go back to where they were. I.E. 3500 to 4500 to 1400 back to 3600. I've messed with the throttle linkage, and that's fine. The butterfly closes all the way, but the idle is unreal.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 01-28-2004, 03:16 PM   #2
Monkey's Avatar
either a vacuum leak or a manifold leak.
Old 01-28-2004, 03:51 PM   #3
Region: Iowa
But wouldn't that always do it? This is an intermittent. I just drove for about 5 min and it was freakin out the whole time. I shut it off, let it sit for 5 min while I got a burger, and when I came back out, it was fine.
Old 01-28-2004, 03:59 PM   #4
Monkey's Avatar
yes and no. i would do it most of the time, but there are freak occurances when it wouldnt. if its a vacuum leak, if the hose is loose and it hits metal obstructing its flow for a min, it wont. etc
pop your hood and make sure every hose goes somewhere.
Old 01-28-2004, 04:20 PM   #5
Region: Iowa
About 90% of the time it runs fine. If it's a gasket is there an easy way to find it with out just replacing it?
Old 01-28-2004, 05:37 PM   #6
tire's Avatar
Send a message via AIM to tire
check all the lines man before you go ripping into her. i had a rough idle when i had a leak but not freaky high like you. when did your new intakes go on? if it's been a while i really doubt it's an intake gasket problem but brandon would know bette rthan me. you haven't messed with your maf or piping recently right?
tire is offline   Reply With Quote
Old 01-28-2004, 05:53 PM   #7
Monkey's Avatar
you can turn the engine on and actually spray a little water near the intakes if it is them. but i would put money on it being just one of the vacuum hoses came loose
Old 02-11-2004, 06:27 PM   #8
has it gotten progressively worse over time, if so you should checkc you ivs and make sure it's workin properly.
All pigs are useless!
widowvirgin is offline   Reply With Quote
Old 02-12-2004, 12:41 PM   #9
Send a message via AIM to Mach_Mustang_R
My car idles at 2500 rpms when I turn my car on, but after I tap on the gas it runs fine, I never thought to check the hoses. Could that be the problem
<B>Current Mods</B>
Dual cat-back exhaust
V-6 cold air induction kit
Mach_Mustang_R is offline   Reply With Quote
Old 02-12-2004, 05:44 PM   #10
my car idles at around 1500 but i think that's the choke working fine...i don't press the gas pedal though, i just let it idle down by itself.
Old 02-12-2004, 06:35 PM   #11
When you first crank your car it idles higher...
Old 02-13-2004, 01:41 PM   #12
aight, thanx for the tip man
<B>Current Mods</B>
my car's new look hottcobra 2005-2010 Mustang GT 68 03-11-2009 09:12 PM
My car's birthday! SpectorV The Bar 26 05-30-2006 04:20 PM
Idle all screwed up johnwayneismyda Pre-2005 V6 Mustang 14 11-26-2005 10:02 AM
Our car's biography.. wiarumas The Bar 49 03-22-2005 03:43 PM
My car's future. I think. WhiteStang99 Mustang Audio & Video 32 12-29-2004 10:47 AM
12:37 PM
