AbS light - Mustang Evolution
Old 09-02-2008, 12:56 PM   #1
2000StangLover's Avatar
Send a message via MSN to 2000StangLover
AbS light
Ok so i was changing my oil today so i said to my self i'll just check everything else in the car. I was looking at the fuse box and i saw i was missing a fuse. So i checked my diagram and put the fuse back in the box. I started my car up and started to drive then i noticed my abs light never with off so i'm wondering if theres something wrong?
Before I put the fuse in i was missing some of my lights in my dash when u first start the car.
I got another question. When u first start the car are all the lights in the dash light up and turn off? Because the traction control light never turns on even if i puss the button.
Help please.
3.8 V6 Mustang with Flowmaster 40
But everything else is stock
Other mods are coming soon
2000StangLover is offline   Reply With Quote
Old 09-02-2008, 01:32 PM   #2
Herbstang's Avatar
Re: AbS light
could be something as simple as dirty front ABS sensors.The light means the ABS system is not functioning. The vehicle is still ok to drive, but the Anti-Lock Brake System will not be functional. Chances are you damaged a wheel speed sensor. When the ABS reads different speeds at different wheels, it will turn on the light an disable the ABS system.
The ABS system works basically by monitoring the speed of each wheel during braking. if a wheel begins to turn slower the the rest, that wheel is locking up, and the ABS system will release some pressure from the brakes ok that wheel. When a sensor is damaged, it will constantly give a different speed reading at that wheel, and will disable the system to avoid complications if it were to try to operate.
Old 09-02-2008, 01:44 PM   #3
Re: AbS light
How much would that cost to fix?
ABS light issue DarkShadows Pre-2005 V6 Mustang 4 03-19-2009 04:45 PM
Brake Light & ABS Light on. stevinas 2005-2010 Mustang GT 1 06-26-2008 02:21 PM
ABS light slick Pre-2005 V6 Mustang 5 04-04-2008 11:31 AM
ABS light Zim 1979-1995 Mustang GT 9 10-13-2006 06:25 PM
ABS and Traction control light on rugman1969 1996-2004 Mustang GT 1 09-30-2006 03:09 PM
11:14 AM
