Best Bang for the buck?? - Mustang Evolution
Old 09-06-2008, 09:40 AM   #1
Scorpion1's Avatar
Ok so Ive been looking around and it seems Eibach offers the best suspension package for the 99 V6. Any opinions on this? I think its a good deal at around $900 for anti-roll bars and the shocks/springs. Anyone ever install these? Major difference between coil-overs and just replacing factory suspension parts with firmer products?(I.E lowering springs and shocks/struts) Or would I be better off with the STEEDA staged products?
WiCK3D_SiX
Scorpion1 is offline   Reply With Quote
Old 09-11-2008, 12:38 AM   #2
Scorpion1's Avatar
Re: Best Bang for the buck??
bump, anyone have the STEEDA staged suspension products? Any good? Im looking for a good suspension for the mustang.
WiCK3D_SiX
Old 09-12-2008, 11:49 AM   #3
1234's Avatar
I like eibach personnaly, the major difference in coilovers and a standard setup is your shock and spring and your car now are seperate and with a coilover they are one piece. IMO the coilover is a pretty stiff ride. Where as the Eibach or Steeda kit would be a bit softer. But either way it would help your car out in handling. And any of the 3 would be a good investement. Oh it also depends on what you want the car to do when you finished (drag, street, or auto-x).
Old 09-12-2008, 02:22 PM   #4
DarkShadows's Avatar
another big advantage with a coilover setup would be you can adjust ride height.
March 2010 Mustangevolution Mustang of the Month 1st eva biatch!
DarkShadows is offline   Reply With Quote
Old 09-13-2008, 01:01 AM   #5
Scorpion1's Avatar
Thanks for the info guys. Makes a big difference. I was origonally thinking straight drag but now Im thinking Auto X, and road courses as its a route I have yet to go.
WiCK3D_SiX
Old 09-22-2008, 08:04 PM   #6
Quality coilovers, such as those from Maximum Motorsports, are notably superior to a conventional spring setup. They offer adjustable ride height, reduced unsprung weight, etc. These advantages results in better handling and ride quality can actually be better than conventional springs with similar wheel rate.
1993 2.3L Notch : Open Track Project
2000 3.8L Coupe : A few mods
2001 5.4L Harley Davidson F150
Blainestang is offline   Reply With Quote
Old 09-23-2008, 07:04 AM   #7
ford racing springs are eibach as well. If I was looking for a good quality suspension upgrade and didnt have the coin to go coil over or the need to I would probably go ford racing c springs 600front/300-350rear linear(130), mach 1 tokico struts/shocks (200), mm cc plates (175), and bullitt sway bars (200~ used), and finish it off with cutting a bit more of the C spring (fine if you dont cut to much...) for a 1.5-1.75 inch drop front and a bit higher in the rear~
Thats 705.00 so far~
I would then upgrade to some MM full length subframes (125) and MM LCAs (300~)
So add on another 425.00
thats a good start the next step would be brake upgrade to a mach 1/cobra/bullitt/etc and that can be done for around 250-300 with ss lines~ maybe 450 if you buy everything new.
This is of course a budget build or a DD/street build you can do better if you wish to autox. You can always do coil overs and a new k member etc etc but thats very costly in the end ... and worthless if you only DD and street drive your car (well to me anyways.. why have it if you wont use it.) Coil overs bring a few issues as well with installation (hitting strut tower insides, rubbing on tires, etc) but once installed and adjusted are great. H&R makes GREAT springs if you are looking for a progressive rate spring that has a higher rate. Mine are 750 front and 770 rear max (IRS rear so higher). What ever springs you get stay 600+ front and 300~+ rear for rate.
Old 09-26-2008, 10:45 PM   #8
Scorpion1's Avatar
Thanks for all the info Ill deffinetly keep this in mind
WiCK3D_SiX
Best bang for buck 100stanggt 1996-2004 Mustang GT 13 05-30-2010 10:02 PM
best bang for buck mustang0386 Pre-2005 V6 Mustang 7 11-13-2006 01:08 PM
best bang for your buck SC kits? Thomas91169 1996-2004 Mustang GT 19 09-23-2006 12:11 AM
Biggest bang for buck mod DropTop_Stang Pre-2005 V6 Mustang 37 01-13-2004 09:44 PM
best bang for the buck amp to power 2 - 250 RMS subs tire Mustang Audio & Video 9 08-05-2003 09:42 PM
02:11 PM
