P420 (reason for SES light) - Mustang Evolution
Old 02-05-2004, 09:42 AM   #1
Mustang Val's Avatar
So, AutoZone checks the stupid a** computer, seems it is a "P420" which, as they explained means the catalytic converter isn't getting hot enough. Any ideas as to what it may be to fix such a silly thing (blow torch on converter?.....kidding).
Thanks for any ideas,
Val
Drive it like you just stole it....
Mustang Val is offline   Reply With Quote
Old 02-05-2004, 12:03 PM   #2
Here are some possible causes and some diagnostic aids.
Have you disconnected the battery like for 20 min. and still give this same fault??
P0420 - Catalyst : Indicates Bank 1
: * Use of leaded fuel : - Compare HO2S :
: System Efficiency : catalyst system : * Damaged HO2S : upstream & :
: Below Threshold (Bank : efficiency is below : * Malfunctioning ECT : downstream switch :
: 1)
: the acceptable : * High fuel pressure : rate. Under normal :
: : threshold : * Damaged exhaust : closed loop fuel :
: : : manifold : conditions, high :
: : : * Damaged catalytic : efficiency :
: : : converter : catalysts have :
: : : * Oil contamination : oxygen storage :
: : : * Cylinder misfiring : which makes the :
: : : * Downstream HO2S : switching frequency :
: : : wires improperly : of the downstream :
: : : connected : HO2S quite slow :
: : : * Damaged exhaust : compared to the :
: : : system pipe : upstream HO2S. As :
: : : * Damaged muffler : catalyst efficiency :
: : : /tailpipe assembly : deteriorates, its :
: : : * Retarded spark : ability to store :
: : : timing : oxygen declines and :
: : : : the downstream HO2S :
: : : : signal begins to :
: : : : switch more rapidly :
: : : : approaching the :
: : : : switching rate of :
: : : : the upstream HO2S. :
: : : : Once beyond an :
: : : : acceptable limit :
: : : : the DTC is set. :
rigs is offline   Reply With Quote
Old 02-08-2004, 11:23 PM   #3
Ponycarman's Avatar
What the code means is that the computer doesn't see the cat as having the desired effect. Why that is so is to be determined. Rigs listed a bunch of possible causes you'll have to eliminate them to confirm the failed component.
Steve
1996 Mustang
1965 Barracuda
Originally Posted by slvr2000stang
Holy crap he's right.
Ponycarman is offline   Reply With Quote
SES: P0411, P1414 geanders Pre-2005 V6 Mustang 15 07-04-2009 04:17 PM
Little help with the SES please? Scorpion1 Pre-2005 V6 Mustang 7 12-10-2008 10:12 AM
Ses P0401 01mineralgrey6 Pre-2005 V6 Mustang 5 10-05-2004 02:57 PM
SES Light - P0420 Code jeffseedman Pre-2005 V6 Mustang 3 07-22-2004 02:28 AM
The SES light, car must of had a fart cross ways Mustang Val Pre-2005 V6 Mustang 8 01-23-2004 09:22 PM
08:17 PM
