The Ram Air Effect Myth. - Mustang Evolution
Old 02-06-2004, 05:08 PM   #1
Dom
Dom's Avatar
Send a message via AIM to Dom
http://www.vetteguru.com/ramair/
Ram Air is just a another way to get air to the filter. The idea was that it acutally "rams" more air into the engine is just that, an idea. It does nothing more than make air available to the intake. It's a sort of like a glorified CAI.
Old 02-06-2004, 05:16 PM   #2
Send a message via AIM to RedDragonV6
I never did think ram air worked as good as people say it does.
2000 3.8L V6 Mustang 4R70W
Full Dual Magnaflow Exhaust with racing H-pipe
Autobadges 232 Emblems (w/ rear emblem)
Steeda Race Wing
BBK Cold Air Intake
Autometer Gauge Pods
Interior Mods
GT Rear Fascia
**Best Track Time**
16.7 @ 87MPH (bad day, did not catch grip..new times soon)
RedDragonV6 is offline   Reply With Quote
Old 02-07-2004, 03:24 PM   #3
Danger Dude's Avatar
It does work once you get to some speed like on a highway up but in city driving wont help a bit. And on a 1/8 dragstrip the usefullness of it wont be there but on a 1/4 mile you would see some advantage but it will be small
Old 02-07-2004, 03:33 PM   #4
Dom
Dom's Avatar
Yea, 70 MPH. Kinda like the effectiness of a spoiler.
Old 02-07-2004, 06:59 PM   #5
very few spoilers ever do anything at any speed.
1998 Subaru Legacy L Sedan
New Hottness
1999 V6 5-speed
14.6 @ 95 w/ 2.22 60'
Wrecked
stangin99 is offline   Reply With Quote
Old 02-07-2004, 07:05 PM   #6
you are referring to street cars I hope. Because on tracks spoilers do preform a function of supply down draft on cars!!!!
Old 02-07-2004, 07:51 PM   #7
Dom
Dom's Avatar
He better have.
Old 02-08-2004, 03:28 AM   #8
Ponycarman's Avatar
I'd suggest reading up on the Baumann effect, boundary layers and NACA's (Nasa's predecessor) investigations into ram air effects.
Ram air does have an effect IF the proper scoop design is used, none of which were used in the cited article. Of course sufficient road speed is needed and it's usually legal highway speeds or better.
Steve
1996 Mustang
1965 Barracuda
Originally Posted by slvr2000stang
Holy crap he's right.
Ponycarman is offline   Reply With Quote
Old 02-08-2004, 09:34 AM   #9
well duh.
slapping on any spoiler to any car wont do squat. You need a windtunnel and some adjustability to get anything from a spoiler.
New Hottness
1999 V6 5-speed
Wrecked
Old 02-08-2004, 02:37 PM   #10
Dom
Dom's Avatar
Then the word money come into play.
Old 02-08-2004, 03:07 PM   #11
well duh.
Pleas do not DUH me
The fact is you dont need wind tunnel test with directional pressure sensitive tape and a few runs you can determine effectiveness. The need for adjustabbility is not necessary in a street car. Given the known limits of a car and the condition it will be driven you can make a permanent spoiler do all you want.
Old 02-08-2004, 08:02 PM   #12
Dom
Dom's Avatar
ding ding ding we have a winner!
:biglaugh:
Old 02-08-2004, 09:39 PM   #13
Ponycarman's Avatar
Not at all, unless you want to spend money frivolously. Research a bit will save lots of money.
Believe it or not those big assed scoops used on drag cars are that way for a reason.
As air flows over the car the layer closest to the body, say about 1/2" thick, is very turbulent. So you have to raise the lowest point of the scoop opening above it.
You then form the rest of the scoop to funnel the high velocity, low pressure air into a convergent path that ends up feeding the intake higher pressure, lower velocity air. Exactly as the guru claimed needed doing. Problem is that none of the factory cars cited do that with thier scoops. That doesn't mean ram air doesn't work, it just means the designs cited are not useful in that application.
That is not to say the design is flawed, it's not, it the application that is wrong. The low drag ducted intakes used on the Firebird and such work great, on a fighter plane where the lowered drag of the ducted scoop far outweighs the loss of ram air effect, but are not appropriate on a low speed vehicle such as a car and I don't care how fast your Mustang is it isn't faster than a P51 Mustang .
Ram air works, if done right. The examples this guru used are not proof that ram air doesn't work, but rather that the particular examples chosen support a preformed theory of his.
Steve
1996 Mustang
1965 Barracuda
Old 02-08-2004, 09:44 PM   #14
Dom
Dom's Avatar
So does the 03 Mach 1 Ram Air scoop work? What about the 03 GT scoop?
Old 02-08-2004, 09:56 PM   #15
Ponycarman's Avatar
The Mach 1 looks like it might work properly but might be a bit too small for much of an effect and it might not have the opening up high enough to clear that turbulent air layer, I haven't looked at it up close only pictures.
The GT's looks doubtful, it's lower opening of the scoop is right in the turbulent layer or air that hugs the body.
One other consideration is that you have to seal the scoop so that all the air flowing into it goes into the engine, the Mach 1 looks like it's sealed up properly. The GT's intake tract doesn't even look to be connected to the scoop at all, it appears to be purely cosmetic.
The problem with using a scoop big enough for ram air to work is that the drag goes up, same as the fighter plane example I mentioned. Pro stock racers don't care about that as the benefit of the scoop outweights the drag. In a street car that drag is there all the time, even when the scoop isn't "helping". Though the drag is less at slower speeds. So in a street car where CAFE standards have to be met you won't see a ram air scoop that is big enough to provide a substantial benefit unless you add one yourself.
So, while the Mach 1 scoop looks to be the right design, it's probably too small to provide much ram air effect.
Steve
1996 Mustang
1965 Barracuda
Old 01-12-2007, 10:12 PM   #16
eagle05's Avatar
Re: The Ram Air Effect Myth.
if pressure and volume is incressed even by a small amount at the throttle plate it would have to increase volumetric efficiey "do we have a spell checker" of the engine and as speed incressed pressure and volume should incress if it is scooping in the air as it should . and for spoilers my stock spoiler on my 79 camaro made it much more stable at 100 mph then my friends 79 camaro that didnt come with a spoiler.
:drive:95 GT T5 K&N filter B&M Pro ripper kicked the cats out and flowmasters :burnout:
eagle05 is offline   Reply With Quote
Old 01-12-2007, 10:18 PM   #17
jimmy_beaner's Avatar
Region: Iowa
efficiency (that's about all I have to contribute to this thread)
Old 01-12-2007, 10:22 PM   #18
eagle05's Avatar
Cool Re: The Ram Air Effect Myth.
Thanks
Old 01-12-2007, 10:55 PM   #19
Titus Wadicus
svtlx's Avatar
i went to flight school....i have text books in my closet that say most of those yahoos dont know crap about aerodynamics. however there r sum people here dat do know there ****. i am a firm believer in aerodynamics, ram air isnt cost effective to me cause i dont drive my car dat fast dat often for it to b worth the expense...a friend of mine disassembled his passenger side headlight to make a ram air scoop on his stang....wtf!!!he says it helps....i dont own a windtunnel so i keep my mouth shut..hell maybe it does
Old 01-13-2007, 05:35 PM   #20
MonteCitan's Avatar
Removing the headlight on the regal gains me, repeatable... 1 MPH/ 2 tenths when its warmer outside, half a MPH/1 tenth when its cold outside (guess when its cold there's more air available anyhow)
I don't think its entirely a myth, anything that allows your engine to breathe more air is a good thing.. (unless it can suck up water/etc)
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 01-13-2007, 07:13 PM   #21
Titus Wadicus
svtlx's Avatar
actualy u can squeze more oxygen molecules together in a given space with cold air....warmer air- the o2 molecules push away from each other...long story short is that you can squeze more oxygen into your cylinders when it is 20 degree outside than when it is 85 degrees...hence the saying "cold dense air equals horsepower" so yes technicaly your car has a lil more ooomph when it is cold out.
Old 01-13-2007, 10:38 PM   #22
MonteCitan's Avatar
not what I was saying, that much I knew (no offense, just trying to make my post clear) I was saying that with the headlight out in warm weather.. made a bigger difference than having the headlight out in cold weather
Old 01-14-2007, 08:41 AM   #23
Titus Wadicus
svtlx's Avatar
u have to excuse me...im not very bright...but i play a smart person on television...lol
Old 01-14-2007, 05:41 PM   #24
MonteCitan's Avatar
Not a problem!
Old 01-14-2007, 05:44 PM   #25
rocknbronco's Avatar
I guess then I will have to rethink my Yugo build man I was gonna do a bad ram air hood on her
rocknbronco is offline   Reply With Quote
Old 01-15-2007, 09:02 AM   #26
Titus Wadicus
svtlx's Avatar
I Know A Guy That Put Nos On His Yugo
Old 01-15-2007, 11:22 AM   #27
How long did it last?
Old 01-15-2007, 04:08 PM   #28
Titus Wadicus
svtlx's Avatar
HE BLEW THE MOTOR THE VERY FIRST TIME HE USED IT....I CANT REMEMBER WUT HORSEPOWER SHOT HE USED THOUGH.
Old 01-15-2007, 06:02 PM   #29
Thats what I figured.
Old 01-15-2007, 09:08 PM   #30
Titus Wadicus
svtlx's Avatar
i think he was one of those power idiots....he probably threw 150 shot on it or sumthin. i bet u could put on a 50 shot wet kit on one and get a couple of passes before u shatter the pistons.......kik'n it up to a whopp'n 118hp...im talk'n trash
Old 01-16-2007, 10:36 AM   #31
if a lawn mower can take a 50 well a Yugo might be able to...
Old 01-16-2007, 03:57 PM   #32
Titus Wadicus
svtlx's Avatar
i say we try it
Old 01-16-2007, 05:00 PM   #33
MonteCitan's Avatar
I say we start a MEBDRA
Mustang Evolution Budget Drag Racing Association...
get one of those nitrous in a bag kits, and when one car blows up just swap it over..
Check to see how many cars can take how much spray before popping.. you know it'd be bad-*** getting a beat up 94ish taurus... running a 150 shot down the track... or a tempo... or an aerostar...
Old 01-16-2007, 06:02 PM   #34
Titus Wadicus
svtlx's Avatar
and where r u get'n this magic money budget from?...im way too selfish for that, dats money outa my stang budget...lol...it sounds good...but get'n enough people to commit funds is another story......but if u r just refering to our make believe world here on da net.....i say hell yea, lets gitter done!!!
Old 01-16-2007, 07:03 PM   #35
MonteCitan's Avatar
well I know someone with this 'nitrous in a bag' kit selling it for $600... it'd be a worthy investment
Beaters in running shape can be found for $50-$100
and if we win vs ricers at the track we can recoup all of that with a nice strong block, say... a 2.3 rustang or something
Custom Ram Air SVTCOBRA Mustang Audio & Video 4 04-28-2009 03:19 PM
Ram air hurting v6? falconplayer79 Pre-2005 V6 Mustang 2 09-09-2008 10:45 AM
Ram Air Induction Dragon_Lady 1996-2004 Mustang GT 6 07-31-2004 10:34 PM
ram air Black00GT 1996-2004 Mustang GT 8 03-23-2004 12:03 PM
RAM air kit jwscorpio Pre-2005 V6 Mustang 6 02-20-2004 12:26 PM
04:29 AM
