mods for supercharging - Mustang Evolution
Old 09-11-2008, 10:24 AM   #1
btant's Avatar
Send a message via Yahoo to btant
Im fixing to buy supercharger for my stang what mods should I get along with it other than the fuel injectors and HP fuel pump I already have a K/N air intake on it.. and were can i find ported and polished heads and what exhaust goes good with a supercharger??
btant is offline   Reply With Quote
Old 09-11-2008, 10:32 AM   #2
Herbstang's Avatar
Re: mods for supercharging
What type S/C are you buying ?? For heads try Redlined Performance Mustangs or http://www.supersixmotorsports.com/ search ebay
Old 09-11-2008, 12:43 PM   #3
Send a message via AIM to VCS_SSSTANG
Anything is better than stock exhaust for a supercharger...
VCS_SSSTANG is offline   Reply With Quote
Old 09-11-2008, 12:58 PM   #4
btant's Avatar
The S/C is a vortech v1 s trim head unit..
Old 09-11-2008, 02:05 PM   #5
Some things to consider:
310 fuel pump
39lb or bigger injectors
gears (3.73 or 4.10s)
tlok (prob want a Detroit Tru Trac)
Long tube headers
catback
Old 09-11-2008, 02:12 PM   #6
btant's Avatar
yeah Ive been talkin to the guy but thanks for the heads up what sites can I get all those from.. I was lookin at borla for my exhaust pretty nice but I cant find a true duel exhaust is that really a big deal..
Old 09-11-2008, 02:32 PM   #7
Borla wont sound super great IMO, and flowmaster won't flow that great for an f/i setup...
Old 09-11-2008, 02:35 PM   #8
btant's Avatar
im probably gonna go with mac set up mac long tube headers mac shorty mid pipes and mac catback system..
Old 09-11-2008, 03:01 PM   #9
btant's Avatar
oh one more thing were can i find the fuel injectors for a 3.8 liter bc all i have found is 4.6 5.0 liter fuel injectors or does it effin matter..lol
Old 09-12-2008, 07:19 AM   #10
Herbstang's Avatar
Here's something I hijacked
Vortech
Pros
*Reliability. The Vortech is one dependable and tough cookie!
*Sound choice. If you like the loud, whining sound of a supercharger, the V1 will deliver. If you want a nice, quiet sleeper sound, you can get a V2. The v2 is slightly more efficient than a V1, but both have the same cost. I believe all newer kits come with the V2 by default
*Availability/Price. There seems to be several used 3.8 kits floating around which makes it easy to get an entire kit for a great price.
*Mounting. The Vortech mounts in a great location. It’s very easy to get to and easy to maintain. In fact, I dismounted and re-mounted mine several times all by myself with no problems.
Cons
*Modification of the A/C line. The kit requires you to modify and tap the A/C line in order to mount the blower. First of all, this is a pain to do. You really need a vice to get this done. Drilling and tapping steel is not easy. Secondly, if you don’t have every joint sealed up perfectly and tight, you WILL have A/C leaks. I LOVE the comfort of A/C, so this was a deal breaker for me. I just couldn’t get the A/C to quit having minor leaks, that’s why I sold the kit.
*Modification of the EGR line. This isn’t that bad really, just a nuisance. I deleted the EGR all together which really helped to clear some room in the engine bay.
*Tapping the Oil Pan. To be honest, it wasn’t hard at all and really could be a “Pro” instead of “Con” because now the Vortech gets a great oil supply which is freshened up every time you change the oil. It just depends on your perspective. Some people just don’t like hacking up their oil pan. Even if you miss-tap, you can still make the oil drain hose work fine, but I’ll put it here because it’s a common concern among inexperienced installers.
*Intercooling. Unfortunately, there are no mass produced intercooling kits available for the Vortech. Vortech makes an “aftercooler” which is a water-air cooler, but it is not available for the 3.8. There simply is no room to put it in between the blower and TB. Options are you can take it to Justin Starkey @ VelocityMustangPerformance.com located in FL for a custom kit, or make your own.
Tools Needed for Install Per Vortech
*3/8" socket and drive set: SAE and Metric
*1/2" socket and drive set: SAE and Metric
*3/8" and 1/2" breaker bars
*3/8" NPT Tap, 3/8-16 Tap and Handle
*Adjustable Wrench
*Open End Wrenches: 3/8", 7/16", 1/2", 9/16"
*Flat #2 Screwdriver
*Phillips #2 Screwdriver
*Heavy Grease
*Silicone Sealer
*Drill and 3/32", 5/16", 7/16", 9/16", 37/64 Bits
*Ford Springlock 3/8" fuel fitting disconnect tool
-or-
Lisle A/C and Fuel Disconnect Tool Set #37000
*5 Quarts SF Rated Quality Engine Oil
*Oil Filter and Wrench
*9/16" Rota-Broach
*T55 Torx Bit
*Tubing Cutter: o5/8" Tube
*Grinder
Download install guide: http://www.taulbeeville.com/images/vortechinstall.pdf
Download supplement (Thanks To SuperSix): http://www.taulbeeville.com/images/V...pplemental.pdf
SUPERCHARGING usmc_berkeley 2011-2014 Mustang GT 5 12-19-2009 10:21 AM
supercharging this b!tch bobbyoooo 1996-2004 Mustang GT 2 04-09-2009 09:15 AM
Supercharging and replacing rear axle and gears for my mustang 2008 bmx_20055 Pre-2005 V6 Mustang 25 02-07-2009 09:06 AM
Milage on 2007 v6,Supercharging Next! ggbiw Pre-2005 V6 Mustang 6 09-24-2007 09:37 PM
Thinking of supercharging - Ken The Bar 20 02-01-2006 09:57 PM
04:40 PM
