nitrous and rev limiter - Mustang Evolution
Old 02-12-2004, 07:38 PM   #1
Send a message via AIM to 02whitestang
right now i have my window switch set at 5200 rpm and i believe that on the 99+ the limiter is set at 5450 and i was wondering if it is wise to put in a 5400 pill into the window switch or is that close to flirting with disaster.
02whitestang is offline   Reply With Quote
Old 02-12-2004, 07:55 PM   #2
tire's Avatar
Send a message via AIM to tire
never do anything with nitrous that will flirt with disaster like that. a chip would be a good investment and you can spray on up to 5.600rpm+.
tire is offline   Reply With Quote
Old 02-12-2004, 08:04 PM   #3
Monkey's Avatar
no, keep the nitrous away from the rev limiter. you hit redline, the fuel pump shuts off and youre spraying. (nitrous would be in the lines before the fuel pump stops pumping and injectors stop spraying). that is ultra lean and bad
nitrous
How can I disable my rev limiter. upton7 1996-2004 Mustang GT 33 04-30-2010 12:49 AM
Dual-Stage Rev Limiter blue-saleen Pre-2005 V6 Mustang 5 12-10-2009 07:00 PM
Nitrous Express wet nitrous kit Zim Mustang Parts for Sale and Wanted 24 06-15-2005 12:43 PM
Speed Limiter starboarder2004 Pre-2005 V6 Mustang 6 02-11-2004 01:14 PM
Rev. Limiter Cut Off Donny B Pre-2005 V6 Mustang 10 12-25-2003 11:25 AM
09:57 PM
