Need quick advice - Mustang Evolution
Old 09-13-2008, 08:14 AM   #1
Scorpion1's Avatar
Need quick advice
I found a NIB Edelbrock wet kit for sport compacts for $350 on a local forum. Will a wet kit work with the 3.8 mustang or would I need a dry kit?
WiCK3D_SiX
Scorpion1 is offline   Reply With Quote
Old 09-14-2008, 11:44 AM   #2
SaturnMan8227's Avatar
Send a message via AIM to SaturnMan8227
Re: Need quick advice
Go wet. I have a wet NOS kit.. used it for years on my Saturn. I wouldnt do more then a 75shot. damn that reminds me i need to install that bad boy on my mustang.
SaturnMan8227 is offline   Reply With Quote
Old 09-15-2008, 12:35 AM   #3
Scorpion1's Avatar
well I talked to one of my buddies today whos a Ford Tech. Hes telling me I can spray the wet shot at 70hp without a tune. Any opinions on this? I can kinda see why being that its a wet shot where as the dry shot only adds gasses so u need to up the fuel. Should I adjust my timing or anything for the spray? Or get a tune like I was gonna?
WiCK3D_SiX
Old 09-15-2008, 07:43 AM   #4
you can spray a 125 shot on a stock motor, i dont reccommend more than 100 though, you probably dont need a tune but it sure makes it safer, and i dont like dry kits
SimplyOrange is offline   Reply With Quote
Old 09-15-2008, 11:26 AM   #5
Wet kits are the best way to go, they mix the nitrous and fuel together in a single fogger. I ran a 75 shot for years on my Saturn. no problems. Just make sure you use WOT or TPS switch to activate the Nitrous System. 91 or better Gas and 1-2 step colder non platinum plugs. you may want to ****** the timing by 1degree
other things I would get are a Air/Fuel Ratio Gauge, a Nitrous blow down safety tube, bottle heater, and bottle pressure gauge.
Old 09-15-2008, 08:56 PM   #6
Scorpion1's Avatar
cool thanks for all the help guys. Last thing i need is to pop this motor its my dd lol
WiCK3D_SiX
Old 09-15-2008, 09:58 PM   #7
yeah dont squeeze under 3500rpms.. a WOT or TPS switch should prevent that
Old 09-15-2008, 11:03 PM   #8
Scorpion1's Avatar
Should I pick up a nitrous controller to help keep it from spraying under 3500 as well? Also would one of those cheap A/F Meters from Advance be ok till I can get a wideband?
WiCK3D_SiX
Old 09-15-2008, 11:34 PM   #9
Send a message via AIM to VCS_SSSTANG
Just save up and get a wide band... Something that wont ever happen again I agree with TPS about hating dry kits.
If your reallly worried about your motor you may want to get some form of a tune to make sure everything is running smooth.
VCS_SSSTANG is offline   Reply With Quote
Old 09-16-2008, 03:09 AM   #10
I am having issues with BBK Trottlebody leaking air help please 1991 mustang gt
lucky is offline   Reply With Quote
Old 09-16-2008, 03:13 AM   #11
I am having issues with BBK trottle-body leaking air
Old 09-16-2008, 05:37 AM   #12
Scorpion1's Avatar
Your best bet is to create your own thread, it will gain more attention that way. Did you test to see where its leaking from?
WiCK3D_SiX
Old 09-16-2008, 11:22 AM   #13
A TPS or WOT switch would be fine, however if you are really worried you can use either one together with a window switch. this will allow the nitrous to only engage between set RPM levels. so even if you happen to be at WOT and below 3500rpms the nitrous system will not engage.
Old 09-16-2008, 06:24 PM   #14
Scorpion1's Avatar
i actually found an edelbrock rpm ativated switch im gonna see if i can find cheaper. any reason 3500rpms?
WiCK3D_SiX
Old 09-16-2008, 10:05 PM   #15
yeah you can pop your motor
Old 09-17-2008, 06:57 PM   #16
Scorpion1's Avatar
haha good to know, thanks for all the help guys! Ive always been weary of using nitrous, always afraid of the whole pressurized bottle cooking in the trunk deal along with the pssst BANG! thing
WiCK3D_SiX
Old 09-18-2008, 11:26 AM   #17
rpm activation has nothing to do with the motor popping, its about breaking the tires loose, i know people spraying at 1500rpms, 2600 is what mine comes in at and i dont think its soon enough for *non track racing*if you spray from 3500 to 5k, you will be disappointed, aslo nitrous is more dangerous at higher rpms than lower rpms just like boost
Old 09-18-2008, 11:40 AM   #18
I've seen several popped motors squeezing under 3500rpms. also seen several from over revving. the rpm window switch is just a good saftey tool. then again i am talking about a weak honda/toyota motor. i've never attempted or seen a mustang squeeze.
Old 09-18-2008, 05:54 PM   #19
Scorpion1's Avatar
I guess what Ill do is start spraying at 3k for now and see how it does then get a mastermind and tune it for progressive spray up to the 100% mark.
WiCK3D_SiX
Old 09-19-2008, 06:09 AM   #20
if you are doing progressive, you can start the spray at 2500 and reach full spray at 4500
Old 09-19-2008, 08:17 AM   #21
Scorpion1's Avatar
Thanks again for all the advice guys, im deffinetly a noob when its comes to nitrous. Oh hey S.O.TPS You know where I could get a CADD Program cheap? Im still not having any luck. The stuff I DL I couldnt get to work right. The Keygens were too old
WiCK3D_SiX
Old 09-19-2008, 09:02 AM   #22
you gonna have to buy it from autocad directly, i got it through my work and it was like $17K for a reusable disc for our whole office, i think its gonna run you about $800 for a personal program.
there are several versions, mechanical, archetectural, and educational, if you are un expierienced, i reccommend the educational one because its a little more self explanitory when compared to the mechanical and you can do either function in it as well as 3D design
Old 09-19-2008, 01:21 PM   #23
Scorpion1's Avatar
thanks for the info I might have to wait for tax return for something like that.
WiCK3D_SiX
Old 09-19-2008, 01:29 PM   #24
if you sling me some hand drawings, ill see what i can do in my spare time an send them back to you
Old 09-19-2008, 03:40 PM   #25
Scorpion1's Avatar
sounds good, I havent even taken dimensions yet heh.
WiCK3D_SiX
I need a quick photoshop please! VendettaV6 Mustang Audio & Video 20 02-02-2007 04:36 PM
desire advice... stock investment type advice... dark The Bar 4 04-23-2006 06:07 PM
quick help jimmy_beaner The Bar 5 05-17-2005 08:02 PM
another quick n/a 3.8 tire The Bar 16 05-05-2004 06:46 PM
One Quick '6 Ken Pre-2005 V6 Mustang 7 11-29-2003 07:49 PM
01:03 PM
