NItrous question - Mustang Evolution
Old 02-15-2004, 10:00 AM   #1
Send a message via AIM to BluStang6
NItrous question
Hey guys sorry for the nobbie question but i have been thinking about puttin a 75 shot of nitrous in my 00 and was just wondering what all i need in order to prepare the engine to take that kind of power or can i just put it in with nuthin' else. I have also heard that a dry shot is safer than a wet. Thanks!
2000 Blue Mustang
Full length Densecharger
Full Boar Dual Exhaust
K&N Filter
NGK's
2 10" Rockford Fosgates
Power 350 amp
4 Infinities
BluStang6 is offline   Reply With Quote
Old 02-15-2004, 10:06 AM   #2
Zim
You want to **** me?
Zim's Avatar
a 75 shot from nitrous express is made to run on a stock car, however its a good idea to get some different spark plugs and a better fuel pump... itll help it out. But basically, yes you can put a 75 shot on your car without doing anything else
I like toys
Old 02-15-2004, 11:57 AM   #3
Monkey's Avatar
like zim said, 75 is perfectly safe on your car. you will need copper spark plugs 1 heat range colder though. you dont need a new fuel pump because 99+ had larger ones from the factory
dry is NOT safer on a wet. you would need a really good dyno tune to run dry on a 99+. the returnless fuel system is responsible. if the MAF doesnt pick up the added air, you run too lean and BOOM! get a wet kit
Old 05-08-2004, 09:17 PM   #4
Suprman's Avatar
Send a message via AIM to Suprman
what about on a 94-98? i'll have a bigger pump and bigger injectors, and probably a tune.
Click On Sig For More Info
http://www.mustangmods.com/data/6447/suprman.jpg
Best 1/4: 15.49@88MPH
Originally Posted by a232stang
SUPRMAN KICKS ***.
Suprman is offline   Reply With Quote
Old 05-09-2004, 03:22 AM   #5
Zim
Zim's Avatar
You'll be able to run a safe 100 shot.
I like toys
Old 05-09-2004, 12:07 PM   #6
Monkey's Avatar
100 shot is actually safer on single ports than on split ports. This is because the nitrous mixture has fewer runners to choose from to get to the cylinder. It will more than likely even out with only 6 runners versus the 12 runners. With the split ports, you can run lean on the corner cylinders because it will tend to move towards the middle.
Old 05-10-2004, 10:52 PM   #7
Suprman's Avatar
sweet, i got a deal on a NX wet kit with the genx2 kit with it and a MSD window switch.
getting it all for $630 shipped
how much should i expect to take off my times running a 75 shot?
SUPRMAN KICKS ***.
Old 05-10-2004, 11:17 PM   #8
Monkey's Avatar
a 75 shot will take off about .9 off your ET. a 100 shot will take off about 1.1-1.2
btw, sell the window switch to make a couple bucks back. You can find much better deals for nitrous used (assuming the price and the stuff, I am assuming you are buying new). You do not need the window switch with your auto. All you have to do is floor it and hit the master arming switch at 3000rpms. they won't fall below that mark when shifting. You could easily make about $75-100 back for the window switch to put towards bottle fills or cds or a t-shirt or something.
Old 05-10-2004, 11:21 PM   #9
Zim
Zim's Avatar
Defanitely sell the window switch.
I like toys
Old 05-11-2004, 08:39 PM   #10
Suprman's Avatar
i got a deal on a NX wet kit(stage one) and GENx2 kit, here's the ad:
NX wet kit, Genx2, MSD window
MSD-8956 RPM activated window switch w/ pills(3200,3400,3600,5000,5200,5400,5600,5800,6000 )
P/N Genx2 upgrade Kit includes: "fully automatic bottle heater with pressure transducer, fuel pressure safety switch, liquid filled N2O pressure guage, NHRA approved pressure release fitting, NHRA approved blowdown tube, purge valve for the NX Ice-Man solenoid"
P/N 20922-10 NX all ford EFI kit with 10lb bottle
7months old, it's all in good condition, The npt adapter and blow down tube will be sent seperatly soon as a deal is made.
I'll probably sell the MSD window switch
oh and i want this to be hidden, but i think i'm gonna put 2 purge lines to each scoop/nostril, i think when i do want to show it off, that will be cool!
the main reson i want to hide it is cops and if i just want to run all motor, which will be most of the time!
SUPRMAN KICKS ***.
nitrous
nitrous question gambit90lx 1979-1995 Mustang GT 10 08-24-2007 07:59 AM
nitrous question? ryanxup Pre-2005 V6 Mustang 63 03-04-2007 06:19 PM
v6 nitrous question blk2kconvstang Pre-2005 V6 Mustang 8 03-02-2004 07:01 AM
Nitrous Question 02whitestang Pre-2005 V6 Mustang 6 12-11-2003 07:46 AM
Nitrous Question ponyboy1995 Pre-2005 V6 Mustang 5 10-13-2003 09:40 AM
05:25 PM
