Help...Temp - Mustang Evolution
Old 02-17-2004, 10:11 PM   #1
Black95GT's Avatar
Send a message via AIM to Black95GT
Help...Temp
Two days ago, I was driving, my antifreeze came out the overflow valve, because my car almost overheated, the temp went to normal to hot in 30 seconds and i pulled over and turned it off. I got my thermostat changed and fluid changed. It runs ok, but my temp is going all the way to the L in normal, and before it stayed under the C the whole time, until i pushed it over 3k. I get no heat in my car, nothing is leaking, and the heads and everthing look ok. Please Help.
-Jason
2003 DSG Cobra -2.2L KB, 60lbs Injectors, Single Blade TB, SCT2400 MAF, Kook's LT's, Kook's High-Flow Catted X-Pipe, Magnaflow CB, JLT RAI, MGW Short-Throw, H&R Race Springs, MM CC Plates, MM Bumpsteer, BF IRS Brace, BF Idlers, and AFS 18 Chrome Reps w/ R888s
Black95GT is offline   Reply With Quote
Old 02-18-2004, 06:32 AM   #2
Ken
Ken's Avatar
Region: New Hampshire
Could one of your hoses have become clogged?
Can't afford Mods? Go To College!
Ken is offline   Reply With Quote
Old 02-18-2004, 07:31 AM   #3
do a compression test, could be a head gasket and the exhaust is pushing into your coolant lines.
1998 Subaru Legacy L Sedan
New Hottness
1999 V6 5-speed
14.6 @ 95 w/ 2.22 60'
Wrecked
stangin99 is offline   Reply With Quote
Old 02-18-2004, 07:42 AM   #4
Danger Dude's Avatar
Here are some possibilities. Thermostat is bad, your radiator was not completely full (you have a small leak somewhere) your head gasket is toast (you have a 95 and if it has not been changed well now its time) or your radiator is clogged or deteriorated.
The fact is our cars have a closed coolant system and will overheat if the system is not completely full or has air in it.
Old 02-18-2004, 10:12 AM   #5
Black95GT's Avatar
The top hose gets warm, however the bottom one stays cooled, alot of air came out the lines today, but i am bringing it back to a mechanic, to take a look.
-Jason
Old 02-18-2004, 10:13 AM   #6
Black95GT's Avatar
I don t think its the gasket because my oil is fine and the exhaust isnt smoking.
-Jason
Old 02-18-2004, 10:21 AM   #7
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
get your cooling system checked by ford. There was a recall in the control module for 94-95's.
Like soemtimes it wouldnt turn the fan on at all, or at the right temp or ect.
Rellik is offline   Reply With Quote
Old 02-18-2004, 10:26 AM   #8
Black95GT's Avatar
i got that replaced when i bought the car
-Jason
Old 02-18-2004, 10:35 AM   #9
Black95GT's Avatar
Thermostat was replaced
No sign of Headgasket Failure
I think the Radiator is clogged, because the top hose to the radiator from the engine is hot, the bottom stays cooled. I am having it checked out.
-Jason
Temp Gauge not working? BILLFORD01 1996-2004 Mustang GT 5 08-06-2009 11:04 AM
Can a mechanical water temp guege be installed. rob4292 1996-2004 Mustang GT 3 05-17-2007 02:16 PM
Decided to keep Water Temp Guage Ibanezplayer272 1979-1995 Mustang GT 2 02-04-2006 04:52 PM
Autometer Lunar Water Temp Gauge FS stangin99 Mustang Parts for Sale and Wanted 0 05-16-2005 04:11 PM
temp. guage question red pony V6 Pre-2005 V6 Mustang 4 03-28-2005 06:56 PM
02:34 AM
