engine rebuild - Mustang Evolution
Old 02-18-2004, 12:49 PM   #1
tire's Avatar
Send a message via AIM to tire
engine rebuild
i will be getting a backup shortblock so i can test the roots blower with confidence. later this week i may pick it up and i want to basically play mechanic with it and rebuild it. where is a good how-to site for a rebuild, or can someone guide me? it is unfortunate but i have little exposure to this stuff except what i persue. the only motorheads i know are on the phone consulting about our project.
if i can find heads and intake for cheap or free i'd like to get it in "ready" mode should my stock motor go kaput. then i can just bolt the acces. on and drop it in.
i know i need to invest in an inch-lbs tq wrench, but what else? an engine stand is neccessary i'd guess? (i guess i could squat on the ground )
btw it's a '94 v6 shortblock with 80k miles on it.
thanks.
-austin
tire is offline   Reply With Quote
Old 02-18-2004, 02:14 PM   #2
Send a message via AIM to NavyStang05
Get yourself a Chilton's Repair manual for the 94-89 stang. Tells you how to disassemble every part of the car, including the entire engine. Most of the pictures are of v-8's, but it gives the specs for v6, gt and cobra. good luck, and we're all lookin forward to the roots blower kits. Rock on man
NavyStang05 is offline   Reply With Quote
Old 02-18-2004, 02:16 PM   #3
also, for parts you need, go to www.stangparts.com
Old 02-18-2004, 02:29 PM   #4
tire's Avatar
thanks navystang, i already got a chiltons for 94-98.
i want to be "one" with the motor, i'll post pics of my "unique" transportation of the shortblock.
Old 02-18-2004, 03:07 PM   #5
Monkey's Avatar
i got $5 says Austin gets the heads off and then either loses a part, or gets further into the engine and breaks a rod or crank seal
Old 02-18-2004, 05:47 PM   #6
Rick0636's Avatar
I am a little confused Austin, why are you building a 94 model single port engine for your 99+ car?
Old 02-18-2004, 06:25 PM   #7
tire's Avatar
its just a shortblock, which means no heads/intake. i need a backup motor in case the roots blower crap decides to port my piston or fubar something else up. if i don't find more heads/intake i would just put the splitport heads/intake from my '00 motor and fuel rail onto the old one.
Old 02-18-2004, 06:34 PM   #8
Send a message via Yahoo to plstktnkr2
tools needed:
1 complete metric and SAE socket set
Ft Lb torque wrench
asst feeler guages both flat and wire (for plugs)
rubber mallet, hammer, wrenches(SAE and metric), torx bits (for some ford headbolts)
engine stand
engine picker (to install)
assembly lube,cam lube, silicone(both blue and copper)
and a torque to yeild dial(degree wheel)
That should get you pretty well there
rick
[SIGPIC][/SIGP
1983 4 eyed GLX Convertible
1966 Lincoln Continental Convertible
1985 Lincoln Town Car Hearse
Local "10-hole Mafia" Don
member of the "Anti-Cowl" club
plstktnkr2 is offline   Reply With Quote
Old 02-18-2004, 07:42 PM   #9
Rick0636's Avatar
I doubt there are any SAE bolts in the 3.8, but then again, anything is possible. I went pretty far into mine and never found anything but metrics there.
Old 02-20-2004, 12:17 AM   #10
tire's Avatar
here is my goal:
1) to get it running, and well
2) to improve performance WHERE CONVENIENT (aka where i can do it myself and cheaply)
i have:
'94:
shortblock needing new pistons, rods are good to go, cam good, all of that intact
u/l intakes
one good head (other one was ****ty and threw away)
crank pulley, water pump pulley, water pump, harmonic balancer
misc. stuff i don't know what it is.
should i take the shortblock apart first and have someone look at it and inspect it? what do they measure, warpage of cyl walls, thickness of cyl walls, or what?
Old 02-20-2004, 11:28 AM   #11
Rick0636's Avatar
Check for out of round, see whether it can be corrected with an overbore, how much overbore to correct, etc. If you are going to use this with the SC blower you might want to get dished low compression pistons? SC crank maybe, just my thoughts?
Old 02-20-2004, 11:32 AM   #12
tire's Avatar
yeah, an SC or a 4.2l crank. i will tear it apart this week and see how it looks. honestly, i'm not sure what to look for, but i know for a fact that the rods are good. they are beefier supposedly in 94-95 than 96+, but i'd want to go with forged 351w rods anyways. i'm sure i can sell these.
Old 02-27-2004, 06:54 AM   #13
RGR
Send a message via AIM to RGR
I have 4.2 and SC cranks here now, not cheap but
the good stuff never is! I am deciding on my engine size
and I may go big bore stock stroke...
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Shortblock or rebuild? sir2much 1979-1995 Mustang GT 14 03-04-2007 11:00 PM
donor rebuild vs current engine rebuild cash05_mustang Pre-2005 V6 Mustang 2 07-01-2006 01:09 PM
Recommend a shop for engine rebuild or swap In2dreamingbig 1996-2004 Mustang GT 2 09-27-2005 01:56 AM
project rebuild 4.6 jimmy_beaner The Bar 22 09-12-2004 06:32 PM
5.0 rebuild. Smokedya95stang 1979-1995 Mustang GT 3 03-15-2004 07:13 AM
02:31 PM
