Any new HP numbers on the venom , rgr, and Ssix kits? - Mustang Evolution
View Poll Results: Should I...
Go 4.3 ? 2 40.00%
Get heads and P&P up/low and cam ? 3 60.00%
Go nitrous ? 0 0%
Voters: 5. You may not vote on this poll
Old 02-21-2004, 01:33 AM   #1
Send a message via AIM to ASSEMbler
I haven't seen any new HP numbers so far. I am getting my tax return so... I want to take this baby from stock to shock!
SIG REMOVED FOR THE PRUDE
ASSEMbler is offline   Reply With Quote
Old 02-21-2004, 09:59 AM   #2
RGR
Send a message via AIM to RGR
I assume you know that a stroker will need all new heads and
camming and hogged intakes to make it run right, correct?
I'd vote for the stroker with big $$$$ but H/I/C for a 3.8
will be around $2000 by itself, and the stroker would add
lots more to the bill I wish we all were independantly wealthy
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 02-21-2004, 10:01 AM   #3
RGR
what year? 99^ strokers can use stock heads easily,
for mild street setups, cuz the heads flow so well.
Old 02-21-2004, 11:13 AM   #4
It's a 2000. My goal is to just get the car turbo. I NEED people he hear a blowoff valve when my car passes. Heh.
I'd probably spend $3500 on either a turbo or a build up N/A..
Old 02-22-2004, 07:31 AM   #5
RGR
turbo cams are the wild card.
you can use a cam NA and turbo but it will
be quite different than an SC or NOS cam.
The best turbo cam will not be a very good NA cam
but it will run OK in the NA form. You may want
to change the cam last. (when the turbo goes on)
Old 02-22-2004, 09:52 AM   #6
Once my new lower goes in, I would technically have an RPM kit, I guess. My lower was self ported so its not ideal but thats last on my mods list.
I should be getting an SCT dynotune sometime this spring, so I will finally have numbers.
1998 Subaru Legacy L Sedan
New Hottness
1999 V6 5-speed
14.6 @ 95 w/ 2.22 60'
Wrecked
stangin99 is offline   Reply With Quote
If this is Venom Seph The Bar 15 05-10-2007 03:20 AM
High Revving 3.8 ltr & "Venom Kits" for the 05 Stang. Extreme Effects.com Pre-2005 V6 Mustang 12 06-11-2004 07:11 PM
RGR Falcon The Bar 7 02-01-2004 11:40 PM
Anyone know where RGR is? Brent The Bar 6 01-22-2004 05:17 PM
RGR tire The Bar 0 12-30-2003 11:05 PM
12:33 PM
