nitrous gauge, how much fluid should it have in it? - Mustang Evolution
Old 02-24-2004, 04:05 PM   #1
tire's Avatar
Send a message via AIM to tire
it is about 70% full when it's at a 90 deg angle. it leaves some air at the top. i am guessing this is fine, but it some came out when i dropped it and popped the cap off. what could i put in there to substitute, or is this fine.
tire is offline   Reply With Quote
Old 02-24-2004, 05:18 PM   #2
Monkey's Avatar
its fine, but its glycerol that is in there if you wanna fill it back up. the only reason its there is to prevent the needle from bouncing. you can even drain it if you desire
Old 02-24-2004, 07:55 PM   #3
tire's Avatar
where do you get dat shiat?
Old 02-24-2004, 08:55 PM   #4
Monkey's Avatar
chemistry lab. or Eckerds should have some. its a natual based lubricant
Old 02-24-2004, 08:59 PM   #5
tire's Avatar
**** i got some ky and some ky warning liquid, would that work?
Old 02-24-2004, 11:43 PM   #6
Monkey's Avatar
technically, you could pee in there and it would work. glycerol is just a thicker substance, so it prevents the needle from bouncing as much
nitrous
Smell diff fluid or tranny fluid when I get on it? ajpturbo 1996-2004 Mustang GT 0 06-19-2010 09:26 AM
Gauge Wire Routing w/CDC gauge pod tripod_2005 2005-2010 Mustang GT 13 04-30-2010 11:46 AM
Nitrous Express wet nitrous kit Zim Mustang Parts for Sale and Wanted 24 06-15-2005 12:43 PM
Too much Transmission fluid? Ibanezplayer272 1979-1995 Mustang GT 2 11-27-2004 05:54 PM
09:57 PM
