need pics of p/p '94-'98 upper/lower - Mustang Evolution
Old 02-24-2004, 07:47 PM   #1
tire's Avatar
Send a message via AIM to tire
especially of the tb opening on the upper. thanks.
austin
tire is offline   Reply With Quote
Old 02-24-2004, 08:56 PM   #2
Monkey's Avatar
just port til you cant port anymore. or if you have a micrometer, 60mm is the max for a single port
Old 02-24-2004, 08:57 PM   #3
tire's Avatar
i was told by clint oteri not to port the tb... to make it into a D shape... and that just porting it all around and gasket matching would lose power.
Old 02-24-2004, 11:26 PM   #4
Monkey's Avatar
yeah, im talking about the plenum. sorry dont touch the TB
Old 02-26-2004, 02:45 PM   #5
Region: New Hampshire
Send a message via AIM to Smokedya95stang
ill get pics hang on
-Charles
Smokedya95stang is offline   Reply With Quote
Old 02-26-2004, 07:19 PM   #6
tire's Avatar
singleport intake btw
1) at the bottom of the lower, should the air in the port go straight into the head, or 2) should it be narrowed slightly for the head, and hog out the rest of the runner with the narrowest part of the runner is where it is gasket matched.... or should it "fan" out, spread out into the head, and polish the inside of the runner, but don't really port it much, just remove the weld seems. and the gasket line match would be the widest margin?
1)
Lower:....| |..........| |....| |
Head: |||||||||||||||||||||||||
2)
Lower: \ /..........\ /....\ /
3)
Lower: / \.........../ \..../ \
Old 02-26-2004, 10:28 PM   #7
Rick0636's Avatar
Got some old ones somewhere....
Old 02-27-2004, 09:25 AM   #8
tire's Avatar
thanks rick, ttt.
Old 02-27-2004, 10:55 AM   #9
Rick0636's Avatar
I have some more where I worked on those heads, I never did finish those though, ended up buying the ones from Morana instead but I did do a lot of work on them.
Porting upper and lower intake stangaroo Pre-2005 V6 Mustang 8 03-09-2010 12:55 PM
GT Upper and Lower Fog Lights. redracer500 Mustang Audio & Video 0 08-04-2008 02:34 PM
Mustang upper and lower intake... jonny5 Mustang Parts for Sale and Wanted 5 05-20-2008 12:04 PM
Ported Upper or Lower first? ntc432 Pre-2005 V6 Mustang 20 05-06-2005 07:04 AM
upper and Lower intakes coolstang Pre-2005 V6 Mustang 8 02-12-2005 11:26 AM
11:30 PM
