Interesting problem - Mustang Evolution
Old 02-26-2004, 05:58 PM   #1
Send a message via AIM to ASSEMbler
Interesting problem
If the car is running, and you open a window, etc the lights dim and radio cuts off. It still runs, just no sound out of the factory amp.
Just discovered this.
If the car is off, and key turned to semi-on, radio and all power works FINE and will NOT cut out the radio if used while it's playing. The lights do NOT dim.
Alternator problem?
RPMS do dip when the car is running and the event happens.
Happens while driving or still. No belt slippage.
SIG REMOVED FOR THE PRUDE
ASSEMbler is offline   Reply With Quote
Old 02-26-2004, 06:00 PM   #2
Yea I would def point to a alternator probem. Have your alternator checked. If its not that its a short somehwere
Old 03-05-2004, 05:55 PM   #3
does the same thing happen when you use another power accessory like mirrors, or seat? test your alt. to see if it's putting out amps. then go from there.
All pigs are useless!
widowvirgin is offline   Reply With Quote
Interesting problem? braumab 2005-2010 Mustang GT 13 01-09-2009 03:00 PM
Interesting computer problem PureVenom The Bar 10 01-25-2006 05:13 PM
Interesting problem.... stangedout916 1979-1995 Mustang GT 7 09-17-2005 12:00 PM
Interesting, very interesting.....hmmm Rick0636 The Bar 6 05-04-2004 11:06 AM
05:30 AM
