alignment question - Mustang Evolution
Old 02-28-2004, 08:01 PM   #1
BlueDonkey's Avatar
alignment question
If you change from a smaller to a larger wheel, does it necessarily change the alignment? The car's feeling a little off-alignment right now, and I was wondering if I'd have to get it re-aligned once I went back to the summer wheels.
BlueDonkey is offline   Reply With Quote
Old 02-28-2004, 08:09 PM   #2
I dont think it would mess it up seeing how your rim is actually the only thing that gets bigger....
Old 02-28-2004, 08:10 PM   #3
Danger Dude's Avatar
Yes it can the alignment is based on the rims that were on it at the time of the alignment. But as long as the ries are balanced it should not be off by alot. It all determines of the tires or rims are wider or not as to how off they will be
Old 02-28-2004, 08:12 PM   #4
BlueDonkey's Avatar
this is going from 15x6 (205 tire width) to 17x8 (245 tire)
Old 02-28-2004, 08:14 PM   #5
what is the offset that is the real difference. How much more weight is on the inside or outside of the rim. It does make a difference
Old 02-28-2004, 08:17 PM   #6
BlueDonkey's Avatar
I'd have to look around for that info. So the best answer at the moment is "maybe, but probably not much"?
Rear alignment? Foxone General Mustang Discussion 3 12-13-2008 10:52 PM
alignment points gearbanger67 Classic Mustangs 3 06-15-2007 08:09 AM
Alignment Issues bodavenport 1996-2004 Mustang GT 4 12-08-2006 12:45 PM
frame alignment Dark02Pony Pre-2005 V6 Mustang 13 12-20-2005 10:12 AM
Alignment problem stang-rookie Pre-2005 V6 Mustang 13 06-14-2005 08:35 AM
02:37 PM
